Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
    is a macro i found on here but it didn't seem to work..
  2. #12
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    this macro was found on here but it doesnt seem to work ..
  3. #13
    Full Member
    AutoCAD LT 2014
    Mar 2015
    28
    sorry the macro did work..
  4. #14
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by buttonbutton View Post
    Can anyone please help ..
    i have a curved 3d polyline that i need to offset autocad lt 2014 wont allow me to do this unless i explode the line, the only issue is that i then have to offset hundreds of individual lines, which i can accept but then i need to select these lines created by the offset to give them a new layer//linetype, etc .. is there any way i can select the items i created on the last operation ie offset . i can do it and it selects the very last line... but am needing it to do for the whole operation .. i hope you understand what i mean ..or am i just going about this the wrong way ??
    Thanks for reading .
    Could you post at least a portion of the drawing. I am not clear if you have a 3dpline, or a pline in 3D, etc.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #15
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Yeah that's the macro (use with care and only on backup copies of a file). And continuing on from there here is a macro that will lump it all together
    Code:
    ^C^C^C-la;n;temp;s;temp;;change;\;p;la;temp;;explode;\;;selectsimilar;l;;move;0,0,0;0,0,1e99;move;p;;0,0,0;0,0,-1e99;pe;m;p;;y;j;j;b;;;o;
    For some reason you have to click on the 3Dpoly twice, the first time it refuses to explode it. This macro creates a "temp" layer and places the new pline onto that layer and finishes by starting the offset command. It may or may not work on your actual 3dpoly, but it's a start. (Don't forget to backup your drawing first.
  6. #16
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Offset now has a layer option. Make the layer that you want them on current and then assign that option in the offset command.
    Drafting is a breeze.
  7. #17
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    306
    Download AutoCAD trial. Run lisp on 3dpolyline. Done. If you only gotta do it once ya know...
  1. Object selection
    By hessoka in forum .NET, ObjectARX & VBA
    Last Post: 6th Jun 2014, 04:29 am
  2. Object selection
    By anp2012 in forum AutoCAD General
    Last Post: 30th Oct 2012, 09:17 am
  3. Object Selection-Gone Bad
    By stevedrew in forum AutoCAD General
    Last Post: 12th Sep 2012, 07:35 pm
  4. Trim selection & Object selection problem
    By Kurt Crim in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2011, 12:19 pm
  5. object selection
    By salman in forum AutoCAD General
    Last Post: 2nd Feb 2010, 10:18 am
