Results 1 to 8 of 8
    Full Member
    AutoCAD 2012
    Feb 2014
    40
    Default How do I edit this Vertex?
    Hello everyone. I'm wondering how I would edit the vertex of the box that is located on the upper left hand corner. Thank you.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    What do you want to do to it?
    I haven't had 2012 in a while so I don't know if this will work but pick on the box and look for grips to use. Or hold CTRL down and pick on the vertex and use the grips, assuming that worked back in 2012.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Full Member
    AutoCAD 2012
    Feb 2014
    40
    Quote Originally Posted by rkent View Post
    What I would like to do is move the vertex. I tried doing that I picked the box and used the grips and that didn't work all that did was move the WHOLE BOX. I would like to move that vertex while the box reminds static.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,770
    Is the cube by chance a 3D object? If so, it will not edit like a regular polyline set. You'll have to edit it according to the parameters for the particular type of entity it is.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Full Member
    AutoCAD 2012
    Feb 2014
    40
    Quote Originally Posted by Dana W View Post
    Are you sure about this? There has to be away to edit this vertex.
  6. #6
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,159
    Click on the object and give us a screen shot of the properties box, is this a solid, a block, an object with thickness, a surface model, a groep........or just a collection of loose lines ?
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,770
    Quote Originally Posted by prime333 View Post
    Not until you answer the question.
  8. #8
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    I can do it in a few steps, convert to a Mesh, stretch the vertex, convert back to solid.
  1. When inserting vertex in pline, jump to the new vertex
    By DieterBvH in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th May 2014, 10:04 am
  2. Replies: 17
    Last Post: 6th Apr 2012, 07:57 pm
  3. Splinedit; edit vertex; weight; change default setting?
    By kouros in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Feb 2012, 11:43 am
  4. Lwpolyline Length (Vertex to vertex)
    By srinivasarajug in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2012, 12:05 pm
  5. Edit Vertex
    By CADbadger in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Mar 2009, 07:59 am
