TheCADnoob Posted November 6, 2015 Share Posted November 6, 2015 Depending on what you are copying you may be able to use design center. ADCENTER. I use it to copy stuff from one drawing to the next, but it doesn't copy general drawing geometry. if you want it to do it that way you just make what ever you are copying into a block and copy it that way. its not a solution to the two window problem but may be another way to address your needs. Quote Link to comment Share on other sites More sharing options...
