Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    Default about plotting with scale
    Hi,I am beginner in autocad and need some help ,please.I can't understand plotting with scale.Here in attached files I am showing what i am doing but there is any mistake I can't find.I prepared Model space to draw in centimetres and drew a line 40cm long.I prepared Layout at A4 and made a viewport.What I saw I think is wrong.A line 40cm long must be seen at scale 1:2 at A4 occuping 60% of the length of a paper A4 which is 29,4cm.What is wrong?Please help!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I'm guessing you used the default template to start your drawing which, as it turns out, is set to use decimal inches. The template file is named acad.dwt. The one you want to use since you are working in metric units would be named acadiso.dwt. Note that this template file is set to use millimeters as its default but can be changed to another metric unit via the -dwgunits command.
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    Thank you for the quick replay.I am using acadiso.dwt.Is it wrong?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    You are using the correct template but you are drawing in millimeters. Use the command -dwgunits and reset it to use centimeters if that is what you want to draw in. You'll have to redraw your line.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Should come out looking something like this:
    My viewport, in magenta, has been created on its own layer.
  6. #6
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    Thank you.This is the solution.But must I make this settings every time I start drawing?These units in my first picture are useless!Are they useless?
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Are the units useless? Only if you never want to draw using millimeters.
    Must you change the setting every time you start a drawing? No. Set it and forget it by incorporating the change in your custom template file along with everything else you normally like to use such as linetypes, text styles, dimension styles, layers, multileader styles, etc.
  8. #8
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    Thank you!!!
  9. #9
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    The only thing wrong was you used an A4 border drawn in mm while you were drawing in cm, so rather than a scale of 1:2 it needs to be 5:1 to account for the difference between a mm border and a cm model space.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  10. #10
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    Hi rkent,I didn't understand what do you mean.I am thinking this way:
    1.I draw a line 40cm long
    2.When create dimension the text of dimension must be 40
    3.After plotting at A4 when I measure the line 1cm will correspond to 2cm of real drawing at Model space.
    Do I make any mistake?
  1. Plotting to a scale
    By PotGuy in forum Revit General
    Last Post: 6th Mar 2014, 10:27 am
  2. scale for plotting
    By detailershub in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Apr 2011, 05:19 pm
  3. Plotting to scale
    By cadg in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2010, 08:03 pm
  4. plotting to a scale
    By DaveyM in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Aug 2010, 09:11 pm
  5. plotting scale
    By BCK in forum AutoCAD Beginners' Area
    Last Post: 17th Nov 2008, 06:20 pm
