Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    rkent:
    What scale would you use if you were drawing this manually on a drafting board to fit on a paper size of A4?
  2. #12
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    scale must be 1:2
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I would agree but apparently when we transition to AutoCAD / paper space / viewports, at least for metric drawings, the scale is 5:1 not 1:2. I'm been doing it wrong it seems. Glad I don't work in metric units.
  4. #14
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    Unfortunately for all the advances in Autocad, scaling remains a problem. You set your units correctly in model space to centimeters, but paperspace always remains millimeters and the standard scale list remains 1 paper unit= 1 model unit, which is 1 mm = 1 cm or in your case 1:2 1 mm = 2 cm (which means 20 mm = 40 cm). Just to confuse you even more keeping the notation used by Autodesk you should really choose the scale 5:1 (which isn't included) as rkent has said. One way to fix this is to use one scale from the list and write a different value in your title block, or alternatively edit all the standard scales in the list taking into account the proper units and then save this as a template file.
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I can only imagine how you'll explain setting the viewport scale in a drawing using imperial units if I wanted to show a line 240 feet long on a 8.5x11 size sheet of paper (portrait mode) yet be able to measure its length using an engineer's scale of 1"=40'. What would the viewport scale have to be?
  6. #16
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    Presumably you are using a file with the units set to feet, I would create a scale and use a scale name of 1"=40' and set the units for paper space as 1 and model space units as 40. Using the same notation as Autodesk uses in their standard scales I would imagine it would read 1" = 40'-0" and would be set as 1 paper unit = 480 paper units because paper space can only be inches.
    You should try working for a company where we work in mm but in house architects work in either millimeters, centimeters, meters, and decimeters. And one draws everything to scale in paperspace.
  7. #17
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    The problem arises when we mix cm (MS) and mm (PS). If MS and PS are both mm then the 1:2 works, but with MS as cm then you have to adjust by a factor of 10.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  8. #18
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by luchoab View Post
    Hi rkent,I didn't understand what do you mean.I am thinking this way:
    1.I draw a line 40cm long
    2.When create dimension the text of dimension must be 40
    3.After plotting at A4 when I measure the line 1cm will correspond to 2cm of real drawing at Model space.
    Do I make any mistake?
    That is correct.
  9. #19
    Forum Newbie
    AutoCAD 2010
    Oct 2014
    7
    At the end I understood.I don't set anything in Model and in Paper space scale 5:1 is what I want.It's 1:2 on a paper sheet.Thank's everybody.
  1. Plotting to a scale
    By PotGuy in forum Revit General
    Last Post: 6th Mar 2014, 10:27 am
  2. scale for plotting
    By detailershub in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Apr 2011, 05:19 pm
  3. Plotting to scale
    By cadg in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2010, 08:03 pm
  4. plotting to a scale
    By DaveyM in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Aug 2010, 09:11 pm
  5. plotting scale
    By BCK in forum AutoCAD Beginners' Area
    Last Post: 17th Nov 2008, 06:20 pm
