Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2014
    Oct 2015
    3
    Default Autocad 2014- Dynamic UCS not working
    I'm relatively new to CAD, self taught, for the purposes of drafting scaled drawings for my company and a few sets of extension plans for friends- so please excuse my limited knowledge, I've also done a search to see if this has been discussed previously.
    Recently (last couple of days) I've started experimenting with 3D modelling and have run into difficulties with the Dynamic UCS function.
    I've been trying create a 3D representation of my house using a 2D layout plan and have followed the following YouTube steps-
    •Layout drawn in plan
    •Clicked bottom left corner of view cube when In the "top" position which alters the view to that needed to 3D model. (Still labelled WCS)
    •Drawn around the plan, then offset to match wall widths
    •Used the press pull function and set walls to height
    •Set lintel heights by drawing around the base and moving up using ORTHO.
    Now this is where the problem lies, when I attempt to draw/cut out the windows and doors-
    •DUCS is turned on, all other functions that arnt needed are turned off
    •Go to draw the Windows/doors but they draw on the plan axis instead of the vertical axis.
    This is where I believe DUCS is supposed to auto change to match the models different faces/axis to prevent you for having to play with the View cube or set a new UCS. The face of the the press pulled solid or polysolid highlight but it still draws On the plan plane.
    I will add that it did work at first, I was able to draw on the vertical axis, however I went to remeasure a window and got waylaid for a few hours, when I came back and started up again it had stopped working and hasn't worked since.
    I've googled the crap out of it, have tried commands like UCSFOLLOW and DYMMODE etc but it doesn't seem to be working, I've also tried starting new drawings from a raw ISO3D template and using a 3Dsolid poly wall instead of press pulling 2D poly lines but experience the same problems.
    Any help or advise would be appreciated.
    Thanks
    Frank
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    The main thing is to pick on the correct surface. In 3D it is easy to think a surface is closest to you when it is actually behind other solids. That is all I can think of, other than being certain you have DUCS on and is not actually off, or you have selected another icon by mistake.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Look also at UCS 3 pick lower left, lower right, top of wall at origin.
    Forum Newbie
    AutoCAD 2014
    Oct 2015
    3
    Many thanks for your comments.
    I know where your comming from with regards picking surfaces, To be sure, I've also tried filtering selections to faces only and it still doesn't work- you can visibly see that the 3D pointer does not blip to the relevant axis when hovering over a particular face.
    Either way, I believe that DUCS should be doing this for you for ease of use, preventing from having to set a new UCS to draw on that specific plane. It is this that appears not to be working, I've toggled on/off by clicking, command and by using F6.
    When I select WCS view and adjust to a particular face it naturally draws fine, but this doesn't cure the issue with DUCS.
    Very frustrating.
  5. #5
    Forum Newbie
    AutoCAD 2014
    Oct 2015
    3
    I've just removed and reinstalled the product and it is now working as it should, however when I open the saved drawing mentioned above, it does not work.
    Not one for leaving problems unresolved, but it works.
  6. #6
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Post a portion of that drawing for us to look at.
  1. vla-put-TitleSuppressed in 2014 not working
    By prakashreddy in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Apr 2015, 08:07 am
  2. Autocad 2014 LT working slow
    By arunz in forum AutoCAD LT
    Last Post: 21st Apr 2014, 01:56 pm
  3. VBA routing working on 65 bit AutoCAD 2014??
    By muck in forum .NET, ObjectARX & VBA
    Last Post: 11th Feb 2014, 02:36 am
  4. Rotating the working plane/flattening geometry? (AutoCAD 2014)
    By Comatosis in forum AutoCAD Beginners' Area
    Last Post: 3rd Dec 2013, 12:04 am
  5. My #1 LISP file isn't working with AutoCAD 2014, any ideas?
    By tzframpton in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Sep 2013, 03:20 pm
