Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    Default can not export 3D file to .stl
    hi,
    I am new in Autocad.
    I have my 3D geometry..
    I need to export to .stl, each time i get attached error..
    Can any one please help me?
    thanks
    Kay
    Senior Member
    not applicable
    Oct 2014
    159
    Hi Kay,
    Can you verify that what you are selecting is a 3D SOLID? You mention 3D geometry - maybe check properties of that geometry to confirm.
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    hi..
    Is it possible for me to send you my dwg file.?
    thanks heaps
    Kay
    Senior Member
    not applicable
    Oct 2014
    159
    Just checking first - did you actually select any geometry when you tried to export the STL file? Seeing the *Cancel* at the select command in your snapshot makes it seem as if you didn't actually complete the selection (thanks, Cad64).
    If you'd like to post a file, I believe the size limit is 1 MB, but I haven't had to post one myself. Someone else may want to chime in here, but I believe that you'll need use the "Go Advanced" link at the bottom right of the reply area to be able to post a file. Once there, you can use the paperclip link to attach a DWG.
    BKT
  5. #5
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    well, i opened my dwg file and then did file export to .stl.. thats all..
    i can clearly see my 3D shapes..
  6. #6
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    i can not upload due to limit .. can u provide an email add?
    thanks..
    i am very new to Auto Cad..
  7. #7
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    a quick overview of my 3D shapes...
  8. #8
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    here is when i select the shapes first then do the export..
  9. #9
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    You can upload the file to dropbox (free account sign up) and then post the link to the file here, but it certainly looks like you don't have 3D solids in your drawing.
  10. #10
    Full Member
    AutoCAD 2010
    Oct 2015
    27
    hi..
    i can assure you i myself drew the 3D file in Global Mapper then exported to .dwg and opened in Autocad..
    now i need to export to .stl.
    here is the dropbox link
    https://www.dropbox.com/s/bcruxit7xbnm17r/make.DWG?dl=0
  1. Export to PDF file
    By Tom Chitwood in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2014, 03:13 pm
  2. Replies: 2
    Last Post: 18th Sep 2011, 06:58 pm
  3. Export/import drawing file to/from csv(text) file
    By mtjipta in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2010, 04:14 am
  4. how shall i export dwg file to 3d max
    By sudhaathreya in forum 3D Modelling
    Last Post: 9th Oct 2009, 06:19 pm
  5. Export DWG file with .txt or .CSV
    By DMS in forum AutoCAD General
    Last Post: 21st May 2009, 03:43 am
Tags for this Thread
