bjenk8100 Posted October 31, 2015 Share Posted October 31, 2015 some of you probably think i am a newb but i cant figure it out. I know extend well. One must use a source to extend to. My problem is stretch. I want to be able to highlight multiple objects and stretch them uniformly if that's a word. For instance, I will keep it simple. I know its possible but cannot do it. Say you draw 4 vertical or horizontal lines parallel to ea other. I want to highlight all of them and be able to stretch/extend them all at once. Everytime I do it they just move. I see people do what I want all the time. I asked and was just told something about crossings or something of htat nature. There is some way to highlight your objects in a particular way to get my intended result. I just cant figure this simple but helpful topic. If anyone can help it would be greatly appreciated. Regards, Brian Quote Link to comment Share on other sites More sharing options...
BKT Posted November 1, 2015 Share Posted November 1, 2015 Hi Brian, I noticed you said you want to "highlight all of them" - you're selecting the ends you want to stretch by windowing around them, aren't you? If you select the whole line the stretch command will act just like the move command. Just checking... Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 1, 2015 Share Posted November 1, 2015 Your selection must be made with a crossing window. Quote Link to comment Share on other sites More sharing options...
eldon Posted November 1, 2015 Share Posted November 1, 2015 Have you tried using Grips? Select multiple grips whilst holding down the Shift key, and when you move one of the hot grips, the other hot grips will follow. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted November 1, 2015 Share Posted November 1, 2015 Say you draw 4 vertical or horizontal lines parallel to ea other. I want to highlight all of them and be able to stretch/extend them all at once. Everytime I do it they just move. Do not window around the entirety of the lines. This mimics the move command. Only window one end of the lines. The other ends will be the anchor points. Quote Link to comment Share on other sites More sharing options...
