Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
    Junior Member
    AutoCAD 2015
    Nov 2015
    14
    Unhappy FloorPlan appears very small on Paper when printed and i need help correcting this..
    Hi all, i am new to AutoCad and as the subject has mentioned, i cant seem to find anyway to correct the size of the plan it appears on the paper. Played around with scales but my it does not work at all.. i Have to submit in a day's time and really need help asap!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    What size paper are you using? What are the overall dimensions of your floorplan? Indicate if you are drawing in imperial feet and inches, or metric mm, cm, M.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Junior Member
    AutoCAD 2015
    Nov 2015
    14
    i dont know the exact dimensions as i merely drew straight away. they are in mm though..
    Junior Member
    AutoCAD 2015
    Nov 2015
    14
    i am using A4 paper
  5. #5
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    Go into modelspace, start the DI command, pick a point to the left of your floor plan, then pick a point to the right of your floor plan. What is the X length?
    Go into paperspace, start the DI command, pick a point to the left of your title block, then pick a point to the right of the title block. What is the X length?
  6. #6
    Junior Member
    AutoCAD 2015
    Nov 2015
    14
    x is 49.99
    y is 24.97 These are for my floorplans
    x is 97
    y is 74 These are for the block title
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Why is your floor plan only 50 mm in modelspace?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    To speed this up, post the drawing here.
    The first thing you need to do, to post a drawing file, is to make sure the .dwg file is less than one megabyte.
    Second thing, click the Go Advanced button at the lower right corner of the posting window.
    Now type your message in the post window, and click on the paperclip icon on the message window. This will bring up the attachment manager.
    Click the Add Files button, then the Choose File button.
    Browse to and select your file.
    Now hit the Upload button on the attachment manager.
    When the file finishes uploading, hit the Done button.
    Then, click Submit Reply.
  9. #9
    Junior Member
    AutoCAD 2015
    Nov 2015
    14
    i simply drew a rectangle and then created some other things within it and when i went to the preview section, i realised it was extremely tiny on the paper
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Did you draw the floor plan using measurements/units at full size in modelspace.
  1. text in paper space appears very thick and solid
    By Dale Bechtel in forum AutoCAD Drawing Management & Output
    Last Post: 6th Dec 2017, 07:53 pm
  2. Changing the size of paper for printed drawing
    By Vagulus in forum Autodesk Inventor
    Last Post: 9th Jun 2014, 04:53 am
  3. Black region appears in paper space...
    By Gjay001 in forum AutoCAD Beginners' Area
    Last Post: 2nd May 2013, 03:39 pm
  4. 'Colored' Text appears feint when printed?
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jun 2007, 01:21 pm
  5. paper too small message
    By C4dm0nk3y in forum AutoCAD Drawing Management & Output
    Last Post: 28th Mar 2005, 06:50 pm
Tags for this Thread
