Sengna Posted November 3, 2015 Share Posted November 3, 2015 I want to change from 19 Deg to 20 Deg by type in from the quick prop table that was show up, when i typed in the calculator showed up but the line was still 19 deg. In the table i should type in 245 deg ref from zero (3 o'clock). Is it posible? i know a difference way to do but would be handy if i can do this way. thanks Quote Link to comment Share on other sites More sharing options...
edwinprakoso Posted November 3, 2015 Share Posted November 3, 2015 That is not possible. Unless you use geometric and dimension constraints Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 3, 2015 Author Share Posted November 3, 2015 That is not possible. Unless you use geometric and dimension constraints I never use geometric and dimension constraints, i used some constraints only for like: pararell, perpendicular, equal...... Quote Link to comment Share on other sites More sharing options...
zaphod Posted November 3, 2015 Share Posted November 3, 2015 it is well worth the time to learn how to use them, they can be very handy. Quote Link to comment Share on other sites More sharing options...
Sengna Posted November 3, 2015 Author Share Posted November 3, 2015 it is well worth the time to learn how to use them, they can be very handy. OK, i will look for some tutorial to learn. thanks. how many different ways that you guys can turn the degree of a line like the one above? Quote Link to comment Share on other sites More sharing options...
zaphod Posted November 3, 2015 Share Posted November 3, 2015 1. drag the grip, result will most likely be random. 2. rotate command 3. dynamics 4. overwrite the text (don't do that) Quote Link to comment Share on other sites More sharing options...
