Results 1 to 1 of 1
Thread: Compound Wall
    Full Member
    AutoCAD 2010
    Oct 2015
    34
    Default Compound Wall
    Hi TZ and the rest,
    I am composing an exterior compound wall with stone veneer on the base about 5 feet high, then upwards is stucco finish.
    I created the exterior finish just the way "No Experience Required" book said, by splitting the two but it stopped short of explaining the scenario I am dealing with:
    a. What if the two finishes have different thicknesses? The book only says to that effect that leave it, it will be handled when the time the finish layer is split and assigned. In my case, the stone veneer is 3/4" thk. and the stucco is 1/2" inch thk.. And I can't type over the cell on the material table because it does not allow (grayed out).
    b. What if there is a molding that separates these two finishes? How can I trim the line (shown in my attachment as a broken line) on the space that is now occupied by the pre-cast molding when I inserted it?
  1. compound curves
    By dannysteel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Aug 2015, 08:51 pm
  2. Wall Merge issue - Infill wall area for presentation purposes
    By tplight in forum Architecture & ADT
    Last Post: 20th Jun 2014, 04:24 pm
  3. Compound angle leg
    By don in forum Autodesk Inventor
    Last Post: 15th Oct 2010, 02:27 pm
  4. Compound Miter in 3D
    By Bill Tillman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Mar 2009, 09:56 pm
  5. Compound Curve?
    By Secretagdan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jan 2008, 03:55 pm
