Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2016
    Nov 2015
    2
    Default Into how many layouts should a model be divided?
    Models with different sizes (m² or ft²) and scales (1:50, 1:100, 1:200, etc.) are divided into different numbers of layouts. I have seen they are either put into a single layout or divided into several layouts. How do you know into how many layouts and at which points a model should be divided to print it out with the right scale and paper size?
    Thanks in advance.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    You don't. It all depends on what you are working on.
    What are we talking about here?
    Forum Newbie
    AutoCAD 2016
    Nov 2015
    2
    I have started working on electrical desings of different structures like hospitals, schools, factories, etc. I have seen different drawings of such projects (electrical, mechanical, architectural, etc.). When the area is too big to fit into the size of the paper used to print out the drawings, they show models into more than one layout, each layout showing a part of the area.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Yes.
    It varies according to a number of factors. A good rule of thumb is to start with the architect's part plans and matchlines. Then make adjustments if needed.
    Drafting is a breeze.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Again it depends on the job. Things like the size of the building, the number of floors, the types and number of electrical equipment will all influence the number of layouts required. You can't just say that for a building of a certain size "X" number of layouts will be required. It doesn't work that way.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Most architectural drafting shops have some standards as far as how the project should be divided up but the standards have more to do with how big your hard copy needs to be and what will fit within one page of that size paper. Therefore, the standards are variable more often than not. For instance, a 12'-0" high structure plotted at 1 1/2" = 1'-0" will be 18 inches tall on paper without dimensions and notes. Where does it fit? Can it be plotted at a smaller scale? How many details of that size and scale will fit on one page? Floor plans can be divided up into logical larger scale sections, for better detailing. However, you will need at least one page for an overall site plan at probably a very small scale.
    You will be drawing each entire floor plan all together in modelspace, and then break it up into logical pieces using viewports in paperspace, the quantity of which depends on what scale you need in paperspace, and how big the building is.
    In other words, we don't know how many layouts there will be, even on what we are working on at the moment.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    I have 88 layouts in one project. Grouped by a common theme this case a multi road project, each road details in sequence.
  8. #8
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    The number of sheets require will also depend on the shape of the building you are working o.
    E.g. an L or S shaped building may require more layouts to show all parts of it than a rectangular building would.
    Good layer management is important when using multiple viewports/layouts.
    Quote Originally Posted by BIGAL View Post
    How do you find the drawing performs in terms of time taken to save it?
    I have one project which is broken up into multiple dwg files (somewhat representing different stages) and each dwg file has 70 to 80 layouts in it. In hindsight I have found that the drawings should have been split into even more .dwg files as 70/80 layouts in a file makes it frustratingly slow to work in/save, e.g. 1 to 2 minutes to save.
    No issues with a single .dwg generally from 20 to 50 layouts in it.
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    I have no problems in terms of speed doing anything, definately less than 1 min to save etc Our servers are offsite but with a Fibre optic backbone. I5 8gb ram.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    yeah, that sounds like network speed there Org...
  1. Layouts to Model's using EXPORTLAYOUT
    By homasa in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2012, 01:59 pm
  2. AutoCAD2013 3D model space to layouts questions
    By aiacs31 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Aug 2012, 01:26 pm
  3. Different LineWeight Display settings for Model and Layouts?
    By BimmerM3 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2008, 10:20 pm
  4. Sharing only the model, not all the layouts
    By Siberian in forum AutoCAD General
    Last Post: 4th Oct 2006, 07:34 am
Tags for this Thread
