AIberto Posted November 5, 2015 Share Posted November 5, 2015 Hi all I use (layerstate-save "layer_color" nil nil) save the layer state. next, I change the layer color use (layerstate-save "layer_color" nil nil) again. then,restore. (layerstate-restore "layer_color" nil nil) I found "layerstate-save" can't overwrite the layer state. Quote Link to comment Share on other sites More sharing options...
tombu Posted November 5, 2015 Share Posted November 5, 2015 I would simply use the Layer States Manager. You could check to see if it's a member of (layerstate-getnames) or just use (layerstate-delete "layer_color") before (layerstate-save "layer_color" nil nil) Quote Link to comment Share on other sites More sharing options...
AIberto Posted November 5, 2015 Author Share Posted November 5, 2015 I would simply use the Layer States Manager. You could check to see if it's a member of (layerstate-getnames) or just use (layerstate-delete "layer_color") before (layerstate-save "layer_color" nil nil) Thank you tombu. I used (layerstate-delete "layer_color") before (layerstate-save "layer_color" nil nil), Just only do this. Quote Link to comment Share on other sites More sharing options...
