Results 1 to 6 of 6
    Forum Newbie
    Subiran's Computer Details
    64 Bit
    Samsung
    4 GB
    AutoCAD 2013
    Nov 2015
    9
    Question Draw a Lot using Coordinates from Google Earth
    Hi. I'm a beginner in CAD, I'm going to ask how to draft a lot using the coordinates(latitude and longitude) from google earth.
    Example:
    Point A.
    Latitude: 11 Degree 18'2.22"N
    Longitude: 124 Degree 57'46.89"E
    Please check my attachment picture.
    Senior Member Andrew1979's Avatar
    Andrew1979's Computer Details
    Windows 7 64 bit
    AMD FX 8350 @ 4.3Ghz
    32Gb DDR 3
    Samsung EVO 128Gb SSD
    WD 1Tb Black
    HP
    Architectural
    AutoCAD 2014
    Jun 2008
    Victoria, Australia
    219
    There is no attachment and I'm not sure I know what you are asking exactly, but I have made a video on how to use degrees, minutes, seconds to draw a site boundary which I think is what you are trying to achieve, but on a bigger scale. If I am correct, the video I have made should show you how to do this. . The video can be viewed here https://www.youtube.com/watch?v=UeQUdXCFTqc
    I'm on a whiskey diet, I've lost 3 days already.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,711
    Convert your lat & longs to X&Y much easier there is some free software out there, CIV3D its built in. I am at like 287123.456,5234567.895
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    380
    You might try the program offered at http://www.earthpoint.us/BatchConvert.aspx to convert a list of latitude longitude coordinates to some other format. If you are in the USA consider state plane coordinates for output as this will give you a nice orthogonal coordinate system in feet. If you are not in the USA you can change the setting in Google Earth to UTM (Universal Transverse Mercator) which yields an orthogonal coordinate system in kilometers which works out nicely if your data does not span UTM zones. Note, specifying latitude/longitude in the degrees-minutes-seconds format can be messy. Change your GE settings to decimal degrees.
    A simple script file can be used to enter the resulting data into AutoCAD.
    ~Lee
  5. #5
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    QGIS *may* be another free option (with loads of other benefits, as an ArcGIS alternative), as you can use it to easily export SHP (Shapefile), etc.
    [Edit] - Most municipalities (in the US at least) post this sort or GIS information on their websites as a free download as well; you really should try to download from the source first, rather than convert Google information, if being used for anything more than an initial exhibit; even then GIS is no substitute for actual survey data.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Quote Originally Posted by BlackBox View Post
    ...... rather than convert Google information.....
    Google Earth converts its own information, all depending on how you set up the coordinates to show as Lat / Long or Universal Transverse Mercator. No further programmes are needed.
  1. Draw a Lot using Latitude and Longitude from Google Earth
    By Subiran in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2015, 05:21 pm
  2. Overlay with Google Earth or Google Map
    By soates in forum AutoCAD Beginners' Area
    Last Post: 11th May 2012, 01:19 pm
  3. KML Google Earth
    By bsimpson in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jun 2011, 03:59 pm
  4. Google Earth Coordinates Don't Match Up
    By jeffj in forum Map 3D
    Last Post: 5th Aug 2008, 05:28 pm
  5. Google Earth
    By joewaianae in forum AutoCAD General
    Last Post: 27th Jan 2008, 10:51 am
Tags for this Thread
