Results 1 to 4 of 4
    Full Member
    AutoCAD 2010
    Oct 2015
    34
    Default Wall Corner Unable to Join
    Attached is a print-out of the reduced building I am trying to assemble.
    I am intending to save a Revit file, just capturing the problem portion so that it can be accessible for diagnoses. But still, I can only go down to 884 kbytes, over the allowable 500 kbytes to upload. So, I settled to pdf-ing.
    It shows two corners, 3 wall forming a U (as seen in plan). The walls are all of the same type and were created in identical procedure. What I don't know is why the right one is misbehaving with the appearance of unnecessary multiple vertical lines while the left part is clean.
    I tried to use the trim (fillet) command, or right clicked on the grip, then disallowed joining so that I can manually meet the walls, or used the wall joins command but it won't get fixed.
    What is the best way to clean this corner?
    I wish I could have the actual file uploaded.
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Federalsburg, Maryland
    312
    Is your right wall inserted as a "block" by any chance ?
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    861
    On the wall join tool, try switching it from butt to miter.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
    Senior Member nod684's Avatar
    nod684's Computer Details
    Windows 7 Home
    Architectural
    AutoCAD 2014
    Jul 2012
    Philippines
    345
    have you tried splitting the ends of both wall?
    split and delete the end walls and join them again
    "Memories fade but the scars still linger...."
  1. Join 2 polilines and deletes the join point Vertex
    By sergiu_ciuhnenco in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Apr 2015, 10:20 am
  2. Wall Merge issue - Infill wall area for presentation purposes
    By tplight in forum Architecture & ADT
    Last Post: 20th Jun 2014, 04:24 pm
  3. how to connect a corner with another corner that is offset inside it
    By bubba7420 in forum AutoCAD Beginners' Area
    Last Post: 20th Jun 2014, 05:14 am
  4. Help with angles in wall corner
    By fitzj in forum AutoCAD Beginners' Area
    Last Post: 19th Feb 2014, 07:31 pm
  5. Join wall with floor
    By Hmm.. in forum Revit General
    Last Post: 23rd Dec 2008, 01:45 pm
