Wall Corner Unable to Join
O'Huggin
Attached is a print-out of the reduced building I am trying to assemble.
I am intending to save a Revit file, just capturing the problem portion so that it can be accessible for diagnoses. But still, I can only go down to 884 kbytes, over the allowable 500 kbytes to upload. So, I settled to pdf-ing.
It shows two corners, 3 wall forming a U (as seen in plan). The walls are all of the same type and were created in identical procedure. What I don't know is why the right one is misbehaving with the appearance of unnecessary multiple vertical lines while the left part is clean.
I tried to use the trim (fillet) command, or right clicked on the grip, then disallowed joining so that I can manually meet the walls, or used the wall joins command but it won't get fixed.
What is the best way to clean this corner?
I wish I could have the actual file uploaded.
Wall Unable to Join.pdf
  • 2 months later...
