Madruga_SP Posted November 11, 2015 Share Posted November 11, 2015 Hi all, How are you? I have a condominium entry file from sketchup and I like to add a outdoor. I'm begginner in sketchup and I need some help. Thank in advance. Fabricio Quote Link to comment Share on other sites More sharing options...
f700es Posted November 12, 2015 Share Posted November 12, 2015 What exactly do you need help with? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 18, 2015 Share Posted November 18, 2015 I'm assuming he probably wanted to know how to add trees and shrubs and stuff like that, but since he never came back, I guess we will never know. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 18, 2015 Author Share Posted November 18, 2015 Sorry guys, I was a little bit busy, lately. I'm working in a project in infraworks software, the software is able to insert a .dae file. and I trying to create a outdoor in the Sketchup. But I don't know how to do that. I tried without sucess. I'll be really happy with you help me out. I'm attaching the imagem of the outdoor. Thank in advance Fabricio Quote Link to comment Share on other sites More sharing options...
f700es Posted November 18, 2015 Share Posted November 18, 2015 The image didn't seem to come across Fabricio. What exactly are you having trouble with? We are going to need some more information Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 18, 2015 Author Share Posted November 18, 2015 The image didn't seem to come across Fabricio. What exactly are you having trouble with? We are going to need some more information Hi, I'd like something like that image. Thank you Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 20, 2015 Share Posted November 20, 2015 Typically, when creating a still image like this, I would render my model from the same angle as the photo and then composite the final image in Photoshop. It's much faster and easier to do it this way than building the whole thing in 3D. This video is a good example: https://vimeo.com/91315595 But, if you're going to be doing an animated fly through, or if you need the ability to rotate around and see everything from different views, you will need to build the whole thing in 3D. I don't do much in Sketchup, so I can't really help you with this, but maybe f700es will have some suggestions. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 23, 2015 Author Share Posted November 23, 2015 Typically, when creating a still image like this, I would render my model from the same angle as the photo and then composite the final image in Photoshop. It's much faster and easier to do it this way than building the whole thing in 3D. This video is a good example: https://vimeo.com/91315595 But, if you're going to be doing an animated fly through, or if you need the ability to rotate around and see everything from different views, you will need to build the whole thing in 3D. I don't do much in Sketchup, so I can't really help you with this, but maybe f700es will have some suggestions. Hi Cad64 Awesome video!! I'm going to study about it. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
f700es Posted November 23, 2015 Share Posted November 23, 2015 The billboard itself is pretty easy as it is just a cylinder, some rectangles and some gussets/flanges at the bottom. The grass and trees will be a problem and should be handled with a 3rd party rendering engine. Vue Esprit would be a good solution for this imho. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted November 23, 2015 Share Posted November 23, 2015 Vue Esprit would be a good solution for this imho. I'll 2nd that recommendation. I have Vue Complete and it is designed specifically for environments. You can import your .dae file directly into Vue and bypass Sketchup completely. Quote Link to comment Share on other sites More sharing options...
