Results 1 to 3 of 3
    Senior Member Squirltech's Avatar
    Squirltech's Computer Details
    Windows 7 Enterprise, Service Pack 1
    BOXX
    32.0 GB
    230 GB
    Single DELL 34" Curved
    Surveying
    Squirltech's Discipline Details
    Project Coordinator
    Surveying
    Civil 3D 2018
    Oct 2010
    30 15' N, 97 44' W
    272
    Question Help with surface
    I need some assistance here...
    I have a surface that was created in Acad 09, Land Desktop (attached file) but there are no .xml files and the original drawing can't be located. The person who did the original drawing, no longer works here (of course).
    Anyway, long story longer, I would like to create a surface from the linework provided, in Civil 2015 format, but I've tried all I know and I'm coming up empty handed.
    Any help would be greatly appreciated!
    Thanks in advance.
    T
    BLOCK-Surface07.dwg
    T. Nelson - Project Coordinator
    http://www.sam.biz/
    "The only thing left to do is EVERYTHING!" - Jesse James
    "Work smarter, not harder" - Unknown
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Took longer to download than to make
    Explode all plines, Add surface, create surface from lines.
    Only BUT! its not as accurate as original model as its converting contour lines to a surface but will be close.
    BOXX
    32.0 GB
    230 GB
    Surveying
    Project Coordinator
    Surveying
    Civil 3D 2018
    Oct 2010
    30 15' N, 97 44' W
    272
    In the original drawing, the lines are exploded.
    Turns out though, it wasn't needed for this project. I had created another surface from a previous Civil3d file, same project, different scope and that's what we ended up using.
    Thanks for the reply though.
    T
    http://www.sam.biz/
  1. Trim a surface with a surface and then delete the cutting surface.
    By triangolo in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Jun 2014, 08:15 pm
  2. create cut fill surface from excisting surface in Civil 3d
    By smileyours in forum Civil 3D & LDD
    Last Post: 1st Mar 2013, 09:26 pm
  3. Subtracting Lofted Surface using Extruded Surface - Doesn't Work
    By dulerong in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Jun 2011, 05:18 pm
  4. Change Comparison surface on a Volume surface Civil 3D
    By cadjunkee in forum Civil 3D & LDD
    Last Post: 30th Apr 2011, 08:03 pm
  5. Replies: 1
    Last Post: 8th Jun 2009, 12:25 am
Tags for this Thread
