mkisno4 Posted November 12, 2015 Share Posted November 12, 2015 Hi again everyone. I had a sheet list set up with the publish command with all my sheets/drawings. However, unfortunately, I had to move the files to a different location last week. Today I opened up the publish command and loaded in my sheet list, but now all my sheets (understandably) cannot be found. It gives me a "Drawing not found" error under "Status". It's not the end of the world if I have to set it all up again, but I figured I'd ask first...is there anyway to quickly 'relink' or change the source of my sheets to the correct location? The files are all named the same thing, just in a different folder. Quote Link to comment Share on other sites More sharing options...
zendrix Posted April 8, 2020 Share Posted April 8, 2020 i have same issue. did you find a solution? Thanks Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted April 8, 2020 Share Posted April 8, 2020 You can open the .DSD file in notepad and do a find+replace. Quote Link to comment Share on other sites More sharing options...
