Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2014
    Nov 2015
    Default message box when close file
    Hello, I'm a new user about autocad and new user about this Forum.
    I try use VB and CAD...
    Is there a solution for my problem in object?
    i just write code for MSGBOX:
    Dim Variabile As Integer
    Variabile = MsgBox("Hai esportato i parametri?", vbOKCancel)
    If Variabile = 2 Then ActiveWindow.Close
    and work if use a macro....but for insert this message when close a file?
    can i make a particular macro for this like excel or access???
    thanks for You interest
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    Look at Redefine it allows a re definition of a command so CLOSE could do something totally different even open a dwg.
  1. Close script file doesn't work in AutoCAD 2014
    By Spiderguy in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 29th Apr 2014, 03:30 am
  2. how can I fix ploting problem and automatic file close
    By Muhammad Mahfooz in forum AutoCAD General
    Last Post: 15th Aug 2013, 10:54 am
  3. AutoCAD Architecture Crashing when trying to close a sheet file?
    By CAD Monkey in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 5th Sep 2011, 11:39 am
  4. Can not Close a Drawing File
    By Rhayes in forum AutoCAD General
    Last Post: 2nd Jun 2008, 09:35 pm
  5. Close without saving and open next file-macro
    By mdbdesign in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th May 2007, 12:44 am
Tags for this Thread
