sarox85 Posted November 13, 2015 Share Posted November 13, 2015 Hello, I'm a new user about autocad and new user about this Forum. I try use VB and CAD... Is there a solution for my problem in object? i just write code for MSGBOX: Dim Variabile As Integer Variabile = MsgBox("Hai esportato i parametri?", vbOKCancel) If Variabile = 2 Then ActiveWindow.Close and work if use a macro....but for insert this message when close a file? can i make a particular macro for this like excel or access??? thanks for You interest Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 13, 2015 Share Posted November 13, 2015 Look at Redefine it allows a re definition of a command so CLOSE could do something totally different even open a dwg. Quote Link to comment Share on other sites More sharing options...
