Results 1 to 9 of 9
    Junior Member
    not specified
    Sep 2006
    21
    Default How do I add textures in auto cad 2006
    I can't work out how to add textures to my shapes in Autocad 2006. Can someone point me in the correct direction. I having trying the mapping tools thinking its what I need but getting nowhere.
    thanks in advance
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Do you mean textures on the rendered images?
    After you assign a texture you must use the RENDER command and you will get a raster image on your screen or in a specified file. Is this what yoy wish?
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Junior Member
    not specified
    Sep 2006
    21
    Yeh what I mean is that if I have drawn a cube I would like to add different textures to each face of the cube. How do I do that? How do I assign texture to a particular face of the cube.
    Super Member yedan's Avatar
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    assigning multiple materials to a solid in autocad is not possible (unless im wrong), the way i do it is to explode your solid into individual faces then aplly the materials to the individual faces, but bear in mind that doing this destroys the solid "cube" and simple creates 6 faces, so you loose all the functions that you can do like subtract and union ect.
  5. #5
    Junior Member
    not specified
    Sep 2006
    21
    Thanks for clearing that up. What I'm trying to do is to model this building. I have taken a digital photo for each of the 4 faces of
    building. I have drawn the building and now I need to attatch the correct image with the corrct side, simple as that. Its just that I have never used autocad before and have spent alot of time trying to work out how to attatch textures to surfaces. How do you assign materials to a particular surface?
  6. #6
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    once you have exploded your solid cube you are left with 6 faces, each of these can have a material assigned seperatly by opening the materials dialogue box and clicking a material in the material list on the left hand side the clicking the "attach" Button, you then pick the face you want the material assigned too, if you have no materials in you left hand list you can create new materials by clicking the "new" button and choosing the picture / colour you need for your material. then its a matter of adjusting the mapping settings to fit the material to you building
  7. #7
    Junior Member
    not specified
    Sep 2006
    21
    Thanks alot it works
  8. #8
    Super Member fahim108's Avatar
    fahim108's Computer Details
    Windows XP Professional
    HP Pavilion dv5000
    Architectural
    fahim108's Discipline Details
    Architect
    Architectural
    AutoCAD 2016
    Apr 2006
    Mumbai, India
    501
    Quote Originally Posted by yedan
    ...assigning multiple materials to a solid in autocad is not possible (unless im wrong), the way i do it is to explode your solid into individual faces then apply the materials to the individual faces...
    Yedan, hold on the Ctrl key to assign materials to individual faces in AutoCAD 2007. Yes it can be done! ...but not for the previous releases... sorry 3dvdt...
  9. #9
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    thanks for the tip, i never knew that
  1. textures not copying
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Sep 2006, 06:49 pm
  2. what happened to all my textures?
    By xersius_x in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2006, 07:04 pm
  3. vERTICAL TEXTURES
    By simonbratt99 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Sep 2005, 01:16 pm
  4. Block textures missing....
    By AMANDALEE in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Aug 2005, 12:04 am
  5. Free Textures !?
    By Clementv in forum Design Software
    Last Post: 9th Oct 2002, 12:16 pm
