Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2016
    Oct 2015
    2
    Default How to select an attribute?
    Hello everybody,
    I have a lisproutine wich will modify the value (add a string before the existing value) of an attibute in an block.
    This works fine but it changes all the attributes.
    Does anybody know how i can change the scrip so i can select the attribute by mouseclick?
    Peter
    Here is the lisp i use:
    (defun c:Test (/ s)
    (setq tekst (getstring "\nVoer in te voegen tekst in: "))
    (princ "\nSelect Attributed Blocks")
    (if (setq s (ssget "_:L" '((0 . "INSERT")(66 . 1))))
    ((lambda (i / sn)
    (while (setq sn (ssname s (setq i (1+ i))))
    (mapcar '(lambda (u) (vla-put-textstring u (strcat tekst (vla-get-textstring u))))
    (vlax-invoke (vlax-ename->vla-object sn) 'getattributes)
    -1)
    ) (vl-load-com)
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,570
    ssget doesn't allow selection of subentities - you will need to use nentsel or nentselp.
    Given the operation your program is performing, you might find this program useful.
    PS: Please edit your post and enclose your code with code tags:
    [code] Your code here [/code]
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Forum Newbie
    AutoCAD 2016
    Oct 2015
    2
    Thanx for helping.
    I tried to make it suitable for user input. There is somthing goiing wrong. Will you please look at it?
    Code:
    ;; (pstext "Prefix Text" "Suffix Text" <mode>)
    ;; <mode> = 0  -  single selection
    ;;        = 1  -  window selection
    ;; Author: Lee Mac 2011  -  www.lee-mac.com
    (defun pstext ( preftext sufftext mode / a e i s )
        (cond
            (   (= 0 mode)
                (while
                    (progn (setvar 'ERRNO 0) (setq e (car (nentsel)))
                        (cond
                            (   (= 7 (getvar 'ERRNO))
                                (princ "\nMissed, try again.")
                            (   (eq 'ENAME (type e))
                                (if (wcmatch (cdr (assoc 0 (entget e))) "TEXT,MTEXT,ATTRIB")
                                    (entmod
                                        (setq e (entget e)
                                              a (assoc 1 e)
                                              e (subst (cons 1 (strcat preftext (cdr a) sufftext)) a e)
                                    (princ "\nInvalid Object.")
            (   (setq s (ssget "_:L" (list '(0 . "TEXT,MTEXT"))))
                (repeat (setq i (sslength s))
                    (entmod
                        (setq e (entget (ssname s (setq i (1- i))))
                              a (assoc 1 e)
    (defun c:tekst_voor_achter_single ( )
      (setq tekstvs (getstring "\nTekst voor: "))
      (setq tekstas (getstring "\nTekst achter: "))
        (pstext "tekstvs" "tekstas" 0)
    (defun c:tekst_voor_achter_window ( )
      (setq tekstvw (getstring "\nTekst voor: "))
      (setq tekstaw (getstring "\nTekst achter: "))
        (pstext "tekstvw" "tekstaw" 1)
    (princ "\nType \"tekst_voor_achter_single\" of \"tekst_voor_achter_window\".")
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,806
    You may be better using a pick a block but do it on attribute that you pick when selecting a block and it returns the attribute tag name. Use the pick pt to get block name using entsel as 2nd go. Lee on the mark as usual.
    Code:
    ; example code to get block name and attribute to change
    (setq ent (nentsel "pick block attribute to change"))
    (setq tagname (cdr (assoc 2 (entget (car ent))))) ; tagname picked
    (setq ptxyz (nth 0 (cdr ent)))
    (setq ent2 (ssget ptxyz))
    (setq bname (cdr (assoc 2 (entget (ssname ent2 0))))) ; block name
    What you want
    Code:
    (setq ent (entget (car (nentsel "pick block attribute to change"))))
    (setq att (cdr (assoc 1  ent))) ; attribute picked
    (setq b (strcat "xxx " att))
    (entmod (subst (cons 1 b) (assoc 1 ent) ent))
    Last edited by BIGAL; 19th Nov 2015 at 09:34 am. Reason: Did home work on lee's suggetsion
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,570
    Quote Originally Posted by pkl View Post
    Thanx for helping.
    A good effort - simply remove the double-quotes around your variables when passing the values to the pstext function, i.e.:
    Code:
    (pstext tekstvs tekstas 0)
  1. Select a block by attribute?
    By titoprax in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th May 2016, 08:39 pm
  2. Cant select attribute
    By Ski_Me in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jul 2015, 07:22 pm
  3. Select Blocks by Name & Attribute Property
    By churchill in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Nov 2013, 01:34 am
  4. Select Attribute and Insert Current Date
    By nod684 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Oct 2013, 04:07 pm
  5. Select block in Autocad and read attribute(VBA)
    By ZORANCRO in forum .NET, ObjectARX & VBA
    Last Post: 19th Sep 2012, 04:11 am
