Results 1 to 4 of 4
    Full Member
    Lithium's Computer Details
    Windows XP
    Acer 22"
    AutoCAD LT 2009
    Jan 2009
    Utah
    67
    Default Can't delete layer because of Block-which is used on another layer
    LT 2009
    "A layer that the block or definition is on will stay "used" until all blocks and their definitions are deleted and purged."
    If I delete the block and the layer on which was used, the block disappears from another layer on which it is used.
    How can I keep the block on layer 'Electrical' while deleting the layer 'Outlets'--the layer on which the block was used?
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Layer Merge, if it is available.
    A selection filter to select all the blocks and assign them to the layer. Then delete the other layer.
    Drafting is a breeze.
    Full Member
    Windows XP
    Acer 22"
    AutoCAD LT 2009
    Jan 2009
    Utah
    67
    It wasn't easy , but Laymrg got the job done. Thank you.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    You're welcome.
  1. Delete everything on a layer (including what's inside a block)
    By KRBeckman in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jun 2017, 06:18 pm
  2. Selected insert block to different layer but will not change to that layer color 8 gr
    By cadmando2 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2014, 11:49 am
  3. Cant delete layer
    By theking in forum AutoCAD Drawing Management & Output
    Last Post: 22nd May 2013, 10:27 pm
  4. Can't delete a layer
    By KarolR in forum Autodesk Inventor
    Last Post: 17th Apr 2013, 08:10 pm
  5. Pdf Layer want to Delete
    By suryatry26 in forum Catch All
    Last Post: 30th Nov 2012, 08:33 am
