Extrude
couves
Well i wanted to make a suporte for stair bases. Like the image shows. But cant fill whats left. Ive tried extrude of an rectangle using path but doesnt work. Do you have any other idea?
Thanks Remark for your help. Can you explain how yo did it?
Scj i think your solution is great. Im going to try it with your explanation to practice and see if i can get there. Ill let you people know. Thanks
Thanks Reark. Ive tried your method and works. the onlu problem is the start. the rectangle must strart flat
Scj ive drawn the two rectangles 1 on "y" and 1 on "x". Im not getting right with the splines because of the curve each spline must make. Can you explain how you drew the splines? Thanks
