Results 1 to 5 of 5
Thread: Publish error
    Full Member squareknees's Avatar
    AutoCAD 2015
    Nov 2014
    72
    Default Publish error
    I don't know if anyone else has this issue but since my support and Autodesk couldn't figure it out maybe it can be figured out here.
    When I am drafting I have multiple drawings open, I tend to copy and paste between drawings. This has caused an issue when I am publishing a finished drawing. When I have multiple drawings open and I try to publish, all of the drawings are listed as unsaved drawing. (unsaved drawing1, unsaved drawing2, etc.)
    I have to close the dialog box and save the drawing that I want to publish, and if I don't do anything between saving and opening the publish command the drawing will be listed and I can delete all of the other pages that are listed. I thought once that I would go through and save all of the drawings then in the drawing that I wanted to print I would save that last. When opening the publish dialog box the only drawing listed correctly was the last one I saved.
    The weird part is that when I have only one drawing open, it doesn't matter if I have saved or not it will list the drawing by name.
    I know this is not an issue that will kill AutoCAD but it bugs the crap out of me and I want it to stop doing it.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I've never seen that "Unsaved" prefix and I use publish a lot when I'm printing. I do not "Automatically load all open drawings", though. I'll try to recreate what you have in the morning to find a cause.
    Drafting is a breeze.
    AutoCAD 2015
    Nov 2014
    72
    Thanks you so much!!!!
    I totally forgot that I had that set. It is VERY rare that I have to plot more then one drawing's layout tabs so I just removed the 'automatically load all open drawing' and now it works (I wish AutoCAD support would have thought of that). I don't have to save the drawing before plotting, and it will just add the tabs from the drawing that I am in. Which are listed with the drawing name and makes it easier because I plot to pdf first and I with the other quirks in the publish command I have to name after it is sent, hey maybe that will be fixed too? I don't care how long I have worked with AutoCAD I can break it like no one's business! When AutoCAD support know you by your first name and dread your requests for assistance you know you have worked in AutoCAD too long!!
    Thanks Again
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I'm glad you got it sorted out. I did try to recreate what you have and tried several settings but did not see the "Unsaved" designation.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by squareknees View Post
    Thanks Again
    Does your publish options say Prompt for Name, or Specify Name? If it says Specify Name, then change it to Prompt for Name. Then, it will show you what it wants to name the output file, and if you like it, you don't have to change it. The drawing file name.pdf is the default. It's usually good enough for me.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. ERROR: Layout not found in publish
    By muck in forum AutoCAD General
    Last Post: 6th Aug 2014, 03:51 pm
  2. Publish to PDF not working, getting error.
    By tharney in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jan 2012, 06:36 pm
  3. Publish graphics error
    By FazBear in forum AutoCAD General
    Last Post: 12th Jan 2009, 01:43 pm
  4. PUBLISH Error!!!!
    By smorales02 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Apr 2008, 09:55 pm
  5. Fatal error! (publish)
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2005, 07:55 pm
Tags for this Thread
