Results 1 to 3 of 3
    Forum Newbie
    AutoCAD LT 2016
    Nov 2015
    5
    Default Field Text Showing Font in preview?
    Hi
    I am trying to get a field to link two texts, so that when the first is edited, the second updates to the same, similar to the =CELL function in excel.
    I can get this to work when using standard text, however when I try to do this with text that is bold and Arial Narrow, the second text displays lots of additional information. I have attached a screen grab of the field window to show what I mean.
    How can I avoid this?
    I am working on AutoCAD LT 2016.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    Try setting a new Text Style which is Arial Narrow and Bold, and then using this textstyle in the fields.
    The extra text is because you are changing the font in the textstyle into Arial Narrow and Bold.
    Forum Newbie
    AutoCAD LT 2016
    Nov 2015
    5
    Thank you I think that has sorted the issue.
  1. Field Text Showing Full Contents Including Font
    By DJBuck in forum AutoCAD General
    Last Post: 25th Nov 2015, 05:41 pm
  2. XREF not showing up in print preview
    By rusty in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jan 2013, 11:59 pm
  3. Thumbnail preview not showing in Explorer
    By garygoude in forum AutoCAD General
    Last Post: 19th Dec 2012, 02:59 pm
  4. insert block preview not showing
    By BIGAL in forum AutoCAD General
    Last Post: 5th Apr 2011, 03:28 am
  5. Xref not showing in print preview
    By BuntyBunty in forum AutoCAD Beginners' Area
    Last Post: 21st Oct 2010, 04:41 pm
Tags for this Thread
