Results 1 to 7 of 7
    Forum Newbie
    AutoCAD LT 2016
    Nov 2015
    3
    Question Is there a way to field data located in a imported excel file?
    The overall goal is to reduce data entry.
    I have an excel file that has been special pasted into my Autodesk AutoCAD LT.
    I want to take information from individual cells and make them into fielded values.
    If you have follow-up questions, I will be happy to answer.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    One day Autodesk will put lisp in LT getting and putting is well documented both ways DWG- Excel, my advice buy alternative software that has lisp. The more smarter you want to work the harder it will get.
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,163
    BIGAL I'm not sure that I 100% agree about the getting harder bit, it can certainly cause a few headaches, and yes it falls a long way short of the capabilities of full Autocad. That said it is possible to get a table contents into a field, you need to use the formula option within the field names dialogue and then from there you have the choice to pick a cell, which refers to a table cell, and Autocad will prompt you for that. It does keep track of the table if it alters after updating the table, but you do need to regen the drawing.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Steven-g you should write a book on how to make LT really work, maybe have a chat to Lee-mac about a web page with all your brilliant suggestions. You may not become a millionaire but it may return beer money. Just a question how many macros do you have ?
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,163
    Shhh
    I am learning web design at the moment. but it's a slow process, and I have seen too many sites pop up and then disappear because they haven't been thought out, I don't intend to just throw something together. It's getting there slowly.
    How many macro's ? probably in the hundreds, if they are usefull is another question altogether
  6. #6
    Forum Newbie
    AutoCAD LT 2016
    Nov 2015
    3
    Default Thanks all: Now for more questions
    Hello all,
    A big thanks to steven-g. I've got my numerical values to work.
    The next step is to play around with cells within the table that contains letters and numbers.
    I will continue to play around with the field command.
  7. #7
    Forum Newbie
    AutoCAD LT 2016
    Nov 2015
    3
    Default Letters
    Hello all,
    I still haven't been able to flush out the letters. Any suggestions?
  1. How to position 3D circles onto the coordinates imported from excel file
    By alinazem123 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Mar 2015, 02:42 pm
  2. export data point to excel file
    By iyant in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2015, 05:19 am
  3. AutoLISP - move value from object data field to elevation field
    By cfculligan in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2014, 08:12 am
  4. Inserting data from an .excel file to .dwg
    By NEXTMARCUS in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Feb 2013, 12:39 pm
  5. Replies: 0
    Last Post: 17th May 2012, 06:33 pm
Tags for this Thread
