Hatch patterns
squareknees
I continue to get errors in my hatch patterns that I have found on the internet. I have one where the error said missing parameter in line 2 now it says missing parameter in line 3. other then reading the code there has to be a way to run these numbers through a program that could tell you what is wrong.
I have dozens of hatch patterns with errors.
*arab3,
30,.05,.52886751,.52885,.9160254,.25055535,-.1,.18340174,-.1,.3660254,-.05771752
330,.53304304,.74998249,.52885,.9160254,.25055535,-.1,.18340174,-.1,.3660254,-.05771752
270,.9660254,.44226497,.52885,.9160254,.25055535,-.1,.18340174,-.1,.36602454,-.05771752
30,.05,.47113249,.52885,.9160254,.3660254,-.1,.18340174,-.1,.25059038,-.05768249
330,.48301270,.72113249,.52885,.9160254,.3660254,-.1,.18340174,-.1,.25059038,-.05768249
270,.9160254,.47113249,.52885,.9160254,.3660254,-.1,.18340174,-.1,.25059038,-.05768249
0,.20414510,.70414519,.91599507,.52885,.30829038,-.1,.14944465,-1.27425511
300,.76188022,.70414519,.91599507,.52885,.30829038,-.1,.14944465,-1.27425511
240,1.04074773,.22113249,.91599507,.52885,.30829038,-.1,.14944465,-1.27425511
180,.76188022,-.26188022,.91599507,.52885,.30829038,-.1,.14944465,-1.27425511
120,.20414519,-.26188022,.91599507,.52885,.30829038,-.1,.14944465,-1.27425511
60,-.07472233,.22113249,.91599507,.52885,.30829308,-.1,.14944465,-1.27425511
0,.2330127,.65414519,.91599507,.52885,.3660254,-.1,.0339746,-1.33199014
300,.7330127,.65414519,.91599507,.52885,.3660254,-.1,.0339746,-1.33199014
240,.9830127,.22113249,.91599507,.52885,.3660254,-.1,.0339746,-1.33199014
180,.7330127,-.21188022,.91599507,.52885,.3660254,-.1,.0339746,-1.33199014
120,.2330127,-.21188022,.91599507,.52885,.3660254,-.1,.0339746,-1.33199014
60,-.0169873,.22113249,.91599507,.52885,.3660254,-.1,.0339746,-1.33199014
I got rid of the spaces between the numbers on the first line and that is when the error jumped to line 3.
I am so confused.
thanks for any help.
Your lines are just too long, try reducing the number of decimal places, there is an 80 character limit for the length of a line in a hatch pattern file. (and lines 9 and 10 have an extra space [.30829038*] and [.3082903*8]
... there is an 80 character limit for the length of a line in a hatch pattern file. ...
I never knew that.
Maybe I'll have to look at some of the patterns I've found in the past, investigate, and resurrect from the "errors" folder.
It might be that one of the errors is actually in the first line.
The format of the first line should be *pattern-name [, description]
So if there is no description, there should be no comma.
Thanks a ton, I was looking and looking for more information on hatch patterns and no matter how long I searched this article never came up in searches!
this help explain a lot!
I didn't realize that it was so important to keep the number of characters under 80 if that would have dawned on me I could have fixed them along time ago without all this frustration!
Thanks so much!
you are currently my hero!
I just google hatch patterns or go to sites like this one where someone mentions that they have a place to get blocks and I check it out and the site also has hatch patterns that I think may be interesting. now that I know that they can't be too long I can just go in an fix them by deleting a few numbers, and spaces to make them work.
One safe way to shorten the pattern lines to 80 characters or less is to duplicate each and edit to split the last four numbers between each pair while dealing with the mentioned extra space in line 9.
HatchKit can automate that transformation:
[font=Courier New]
;        Written by HatchKit for AutoCAD
;        HatchKit for AutoCAD (c)1990-2015 Cadro Pty Ltd
;        [url="http://www.hatchkit.com.au/"]www.hatchkit.com.au/[/url]
;-Date                                   : 2/12/2015
;-Time                                   : 10:32:38 AM
;-HatchKit Version                       : 3.1.7.2627
;-HatchKit Output Filetype               : AutoCAD format
;-------------------------------------------------------------------------------[/font]
[font=Courier New]
*arab3
59.9991788178,-0.01699,0.2211,0.915987498494,0.528863133293,0.366,-1.46600532188
59.9991788178,0.8,-0.095855,0.915987498494,0.528863133293,0.36603,-1.46597532188
29.9991789877,0.599,0.8459,0.528836879316,0.916002656235,0.366,-0.69172627202
29.9991789877,0.05,0.47113,0.528836879316,0.916002656235,0.36603,-0.69169627202
0,0.23301,0.65415,0.916025397113,-0.528850005,0.36603,-1.4660208
0,0.36699,-0.21188,0.916025397113,-0.528850005,0.36603,-1.4660208
-29.9991785186,1.082,0.433,0.528889395205,0.916002660565,0.366,-0.691726267021
-29.9991785186,0.483,0.7211,0.528889395205,0.916002660565,0.366,-0.691726267021
-59.9991786614,0.05,0.10511,0.916017816172,0.528863135793,0.36603,-1.46597531322
-59.9991786614,0.733,0.6542,0.916017816172,0.528863135793,0.366,-1.46600531322
-90,0.91603,0.47113,-0.52885001,0.9160254,0.36603,-0.69167001
-90,0.96603,-0.19169,-0.52885001,0.9160254,0.36602,-0.69168001
59.999178818,-0.074722,0.22113,0.91598749849,0.52886313329,0.30829,-1.5237153219
0,0.20415,0.70415,0.916025397113,-0.528850005,0.30829,-1.5237608
0,0.45359,-0.26188,0.916025397113,-0.528850005,0.30829,-1.5237608
-59.9991786614,0.7619,0.7042,0.916017816172,0.528863135793,0.3083,-1.52370531322
-59.9991786614,0.05,0.005107,0.916017816172,0.528863135793,0.3083,-1.52370531322
-119.718085992,1.0421,0.22269,105.341618034,0.0090402866494,0.3051,-106.86850105
29.9991789877,0.05,0.52887,0.528836879316,0.916002656235,0.25056,-0.80716627202
29.9991789877,0.699,0.8459,0.528836879316,0.916002656235,0.2506,-0.80712627202
-29.9991785186,1.132,0.3464,0.528889395205,0.916002660565,0.2506,-0.807126267021
-29.9991785186,0.533,0.75,0.528889395205,0.916002660565,0.2506,-0.807126267021
-90,0.96603,0.44226,-0.52885001,0.9160254,0.25056,-0.80714001
-90,0.91603,-0.27829,-0.52885001,0.9160254,0.25059,-0.80711001
29.9991789877,0.3536,0.7042,0.528836879316,0.916002656235,0.1834,-0.87432627202
29.9991789877,0.4536,0.7042,0.528836879316,0.916002656235,0.1834,-0.87432627202
-29.999178519,0.8866,0.48812,0.5288893952,0.91600266056,0.1834,-0.87432626702
-29.999178519,0.83663,0.5747,0.5288893952,0.91600266056,0.1834,-0.87432626702
-90,0.96603,0.09171,-0.52885001,0.9160254,0.1834,-0.87430001
-90,0.91603,0.0051071,-0.52885001,0.9160254,0.1834,-0.87430001
60.2819140078,0.7598,-0.2605,105.341618034,0.0090402866494,0.1408,-107.03280105
59.9991788178,0.1294,0.5747,0.915987498494,0.528863133293,0.1494,-1.68260532188
0,0.20415,-0.26188,0.916025397113,-0.528850005,0.14944,-1.6826108
0,0.61244,0.70415,0.916025397113,-0.528850005,0.14944,-1.6826108
-59.999178661,-0.07472,0.2211,0.91601781617,0.52886313579,0.1494,-1.6826053132
-59.9991786614,0.966,0.3506,0.916017816172,0.528863135793,0.1494,-1.68260531322
59.9991788178,0.216,0.6247,0.915987498494,0.528863133293,0.03398,-1.79802532188
59.9991788178,0.733,-0.2119,0.915987498494,0.528863133293,0.03398,-1.79802532188
0,0.69904,0.65415,0.916025397113,-0.528850005,0.033975,-1.7980758
0,0.23301,-0.21188,0.916025397113,-0.528850005,0.033975,-1.7980758
-59.999178661,-0.01699,0.2211,0.91601781617,0.52886313579,0.03398,-1.7980253132
-59.9991786614,0.966,0.2506,0.916017816172,0.528863135793,0.03398,-1.79802531322[/font]
Hope this helps,
Hugh Adamson
