Casio47 Posted December 1, 2015 Share Posted December 1, 2015 Hello, I have two .dwg files, one on each monitor. How can I copy one object in one file and paste it into the other? Is copy and paste the correct way to do this? And, will all the dimensions come out the same when it moves into the other file? Or, Is it acceptable to select the entire object, and simple drag it into the other file on the other monitor? Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 1, 2015 Share Posted December 1, 2015 You should be able to do a copy/paste from one drawing to another. What do you mean "Will all the dimensions come out the same"? You aren't drawing "to scale" are you? And you aren't working in imperial units in one drawing and metric units in the other are you? Quote Link to comment Share on other sites More sharing options...
