Results 1 to 7 of 7
    Junior Member
    AutoCAD 2013
    Nov 2015
    11
    Default Separate Mtext to individual text
    Currently, I have an Excel table. Numbers of column contains 0 or 1.
    I have to copy column by column into notepad and then copy the notepad contain to CAD.
    After that, I have serval individual column of Mtext. Then I further explode them into text.
    A numbers of individual text are pasted on CAD and this is what I want.
    However, if I do copy multiple column into notepad, the result is a whole Mtext which is containing all columns. I explode the Mtext and I will obtain multiple line of text.
    I am searching for a lisp to convert/separate Mtext to individual text.
    For more advance, I want these 1 and 0 located in different destination point from excel to CAD by a lisp.
    Senior Member
    Happy Hobbit's Computer Details
    Win 7
    Electrical
    AutoCAD 2014
    Jun 2012
    Dorset, England
    175
    I found this somewhere, the user copies text from Excel or Word for example. The user invokes the PSTSP command & the text gets pasted as individual text items. I've changed it slightly to capitalise the text:
    Code:
    (defun c:PSTSP (/ _GetClipBoardText ent_last last_ent pt str)
     (vl-load-com)
      (defun _GetClipBoardText (/ htmlfile result)
        (setq result
               (vlax-invoke
                 (vlax-get
                   (vlax-get
                     (setq htmlfile (vlax-create-object "htmlfile"))
                     'ParentWindow
                   'ClipBoardData
                 'GetData
                 "Text"
        (vlax-release-object htmlfile)
        result
      (if (not (setq ent_last (entlast)))
          (entmake '(
                     (0 . "POINT")
                     (100 . "AcDbEntity")
                     (100 . "AcDbPoint")
                     (10 . (0.0 0.0 0.0))
                last_ent ent_last
      (if (and (setq str (_GETCLIPBOARDTEXT))
               (setq pt (getpoint "\nSpecify text start point: "))
          (setq str (strcase str))
          (entmake (list
                     '(0 . "MTEXT")
                     '(100 . "AcDbEntity")
                     '(100 . "AcDbMText")
                     (cons 10 pt)
                     (cons 1 str)
          (command "_.explode" "_L")
      (if last_ent
        (entdel last_ent)
    Junior Member
    AutoCAD 2013
    Nov 2015
    11
    Thank you!
    However, I would like to do this:
    If I copy muliple column in Excel, the result is left one.
    I want the right instead of left.
    Each 1 and 0 should be seperated text.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    There are lots of examples of read excel file into Autocad via each individual cell as say a text value. Have a search here for "excel", you do not need a intermediate step via notepad etc.
    There was something maybe last week will try to find.
  5. #5
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,067
    This tool may have what you want : http://www.cadtutor.net/forum/showth...ext-editor-RLX
    Follow instructions (rename vt.lsp to vt.vlx and then use (load "vt.vlx") ...)
    When you start the command press space or R-mouse to start quick menu and select function PasteSpec. Rest should be easy.
    gr. Rlx
  6. #6
    Junior Member
    AutoCAD 2013
    Nov 2015
    11
    Thank you BIGAL and rlx!!
    I found Lee Mac: http://www.lee-mac.com/readcsv.html and I am successful to use this to make as individual text.
    rlx, I tried your lisp. It is quite powerful lisp.
    However, I want more code example to study how to write a lisp for a task.
    By the way, thank you all a lot!
  7. #7
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,067
    Quote Originally Posted by CloudJack View Post
    You're welcome , see also link below , last part of lsp has the excel code
    http://www.cadtutor.net/forum/showth...or-lsp-amp-dcl
    Gr. Rlx
  1. Rotating lots of individual bits of text at once
    By Barneel in forum AutoCAD Beginners' Area
    Last Post: 9th Sep 2013, 06:00 pm
  2. Individual Text Object
    By mac111 in forum AutoCAD Beginners' Area
    Last Post: 20th Jun 2011, 03:06 am
  3. separate mass overlapping text.
    By hay123 in forum AutoCAD General
    Last Post: 2nd Dec 2008, 11:56 am
  4. How to separate text into individual lines?
    By Chris333 in forum AutoCAD Beginners' Area
    Last Post: 29th Oct 2007, 01:14 pm
  5. Exporting individual layouts to separate drawings?
    By Gideon in forum AutoCAD General
    Last Post: 5th May 2005, 03:53 pm
Tags for this Thread
