It could be not in autocad, but in the mouse settings in windows themselves. Find out what kind of mouse you have (exactly model and everything) then search for it on the web. I've had to do that before numerous times.
Hi Everyone
Another person here will be using my computer so I set him up as another user. When I opened Autocad under his user name I had to set up everthing all over again. I've done this a number of times and never had a problem.
I haven't changed any settings. Just created tool bars and changed some colors. The problem is the wheel on the mouse won't pan. When I press it I jump to another window I have running. I have tried mbuttonpan - on 1 and 0 and neither worked. It works fine when I'm in my user space. I just installed 2007LT about a month ago and I didn't have to do anything with the mouse.
Whats wrong?
Valerie
Hi,
Check the MBUTTONPAN variable. Set to 1.
Bye,
Yolanda
Thanks Pennylove, that was the problem
