ptatohed Posted December 11, 2015 Share Posted December 11, 2015 I just got Release 2016. The rubber band is yellow/orange and is hidden/dashed. Can I change the color and linetype? Thanks. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted December 11, 2015 Share Posted December 11, 2015 If it's not available in Options, then no. Maybe a clever programmer could find a hook and write a routine (I'm thinking in the vein of QuikPik here...) to change it....? Quote Link to comment Share on other sites More sharing options...
Organic Posted December 13, 2015 Share Posted December 13, 2015 What is the 'rubber band'? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted December 14, 2015 Share Posted December 14, 2015 For example: When you are moving an object, it's the line that connects the old location of the object and the location to which you are moving it. Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted January 1, 2016 Share Posted January 1, 2016 This is taken from the Autodesk website: You cannot modify AutoCAD 2015 rubberband line color . I would assume the same is the case with all versions of AutoCAD Quote Link to comment Share on other sites More sharing options...
