Can't save texture on surface
Zox
I'm doing some 3d model and whenever I open the project the texture called "Beechwood-Honey" is not on the assigned surface and I have to put it on back every time. All other textures are memorized but not this one. Anyone knows what's the problem?
edit: it also won't remember some other textures and also some of the same textures but on different surfaces also are not there when I re-open.
Edited by Zox
It seems to correspond to the way I put the texture on. If I put it only on one surface (by holding "ctrl" key) Autocad may not save it, but if I put texture on the whole object then it will save it for sure.
