Auto lisp routine to bisect a line and draw a line perpendicular from midpoint
rvalusa22
Hello All,
I need to bisect a line and draw a line perpendicular from mid point and with user defined length using AUTO LISP routine? Your help is very much appreciated.
Thanks
rajesh
This?
(defun c:Test (/ l s e 1p 2p 3p ang c g)
 ;; Tharwat 23.Dec.2015 ;;
 (if (and (setq l (getdist "\nSpecify length of line :"))
          (setq s (car (entsel "\nSelect Line :")))
          (eq (cdr (assoc 0 (setq e (entget s)))) "LINE")
          (setq 1p  (cdr (assoc 10 e))
                2p  (cdr (assoc 11 e))
                ang (angle 1p 2p)
                c   (mapcar '(lambda (q p) (/ (+ q p) 2.)) 1p 2p)
          (princ "\nSpecify distination :")
     (while (eq 5 (car (setq g (grread t 13 0))))
       (redraw)
       (grdraw c
               (setq 3p
                      (polar c
                             (apply (if (> 0 (sin (- ang (angle 1p (cadr g)))))
                                    (list ang (* pi 0.5))
                             l
               -1
               0
     (if (member (car g) '(2 3 25))
       (entmake
         (list '(0 . "LINE") (cons 10 c) (cons 11 3p))
 (redraw)
  • 9 months later...
Read Lee Mac's post just above yours and then go to the thread he indicates and try his first code. I think it will work fine as long as your polylines have only 2 vertices.
BKT there are ways of picking a section of a pline, so in this case this would give the answer of between 2 points. Lee ?
Here is a modified version compatible with both lines & 2D polylines:
(defun c:per ( / ent enx par pt1 pt2 sel )
   (while
       (progn (setvar 'errno 0) (setq sel (entsel "\nSelect line or polyline segment: "))
           (cond
               (   (= 7 (getvar 'errno))
                   (princ "\nMissed, try again.")
               (   (null sel) nil)
               (   (progn
                       (setq ent (car sel)
                             enx (entget ent)
                       (not (wcmatch (cdr (assoc 0 enx)) "LINE,LWPOLYLINE"))
                   (princ "\nSelected object is not a line or polyline.")
               (   (if (= "LINE" (cdr (assoc 0 enx)))
                       (setq pt1 (trans (cdr (assoc 10 enx)) 0 1)
                             pt2 (trans (cdr (assoc 11 enx)) 0 1)
                       (setq par (fix (+ 1e-8 (vlax-curve-getparamatpoint ent (vlax-curve-getclosestpointto ent (trans (cadr sel) 1 0)))))
                             pt1 (vlax-curve-getpointatparam ent par)
                             pt2 (vlax-curve-getpointatparam ent (1+ par))
                   (vl-cmdf "_.line" "_non"
                       (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) pt1 pt2)
                       (strcat "<" (angtos (+ (angle pt1 pt2) (/ pi 2.0))))
(vl-load-com) (princ)
