muck Posted January 4, 2016 Share Posted January 4, 2016 When you open AutoCAD 2013 it goes directly to the drawing editor. When you open AutoCAD 2015 it goes to a menu screen that has "Getting Started", "Recent Drawings" , "Connect" , etc. Is there a way to make AutoCAD 2015 open directly to the drawing editor without going through all this startup menu stuff? Thank you, Quote Link to comment Share on other sites More sharing options...
BlackBox Posted January 4, 2016 Share Posted January 4, 2016 Consider the STARTUP system variable. Cheers Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 5, 2016 Share Posted January 5, 2016 Consider the STARTUP system variable. Cheers As per BlackBox, I have attached a screenshot of my SYSVDLG box in 2013. The settings may be different in 2015, not sure, but enter SYSVDLG at the commandline, hit Enter and it will take you to the system variable dialog, wherein you will find such information exhaustively documented. Quote Link to comment Share on other sites More sharing options...
