Results 1 to 9 of 9
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    Default Thawing Layers that are Viewport Frozen
    Hello All,
    I have looked around a little bit and haven't been able to find the answer I am looking for. I know commands like LAYTHW AND LAYON. I also used the info from "Michael's Corner" latest post. Everything is turned on and everything is thawed. However, it does not thaw layers that are labeled as VP Freeze. Instead of going to the layer properties manager, select all, and thawing the layers that are frozen in the view port freeze, is there a way to thaw all of them with a simple command or a button that is already created or one that I can make in the CUI? As always, any and all comments are appreciated. I have a feeling ReMark, BlackBox, BIGAL may have some insight in to this, or at least point me in the right direction.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I have not been able to find anything that does this. Since you would have to go to the trouble of activating the viewport, it's just another couple of steps to thaw the layers. You can sort the VPFrozen layers by clicking on the header making them easy to pick and thaw.
    Drafting is a breeze.
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    So this is the method that I used to thaw all the layers. Running a LISP. Running this will allow you to thaw all the layers in the current viewport or all of them. This is the text for it:
    This will do that in all Viewports in all Layouts in the drawing, and return you to the Layout you were in when you started:
    (setq clayout (getvar 'ctab))
    (foreach layout (layoutlist)
    (setvar 'ctab layout)
    (command "_.vplayer" "_thaw" "*" "_all" "")
    (setvar 'ctab clayout)
    The (command) line only above will do it in all Viewports in the current Layout only. This will do it in the current Viewport only, if you're in one:
    (command "_.vplayer" "_thaw" "*" "" "")
    I got this from another forum on autodesk's site.
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    320
    There's an option to "Thaw layer in all viewports":
    Open the layers properties box and find the layer you want to change.
    Right click on it.
    The bottom option of the third section down is "VP Thaw layer in all viewports"
    dJE
  5. #5
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Good find. I'm a big right click fan and missed that one.
  6. #6
    Senior Member Andrew1979's Avatar
    Andrew1979's Computer Details
    Windows 7 64 bit
    AMD FX 8350 @ 4.3Ghz
    32Gb DDR 3
    Samsung EVO 128Gb SSD
    WD 1Tb Black
    HP
    Architectural
    AutoCAD 2014
    Jun 2008
    Victoria, Australia
    219
    Yeah I had to write a LISP routine too to do the same thing as I'm not aware of any commands integrated into AutoCAD
    I'm on a whiskey diet, I've lost 3 days already.
  7. #7
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    Right on! I wasn't able to find any commands that would do this either. Andrew, was your LISP anywhere close to the one that I posted?
    Just curious
  8. #8
    Windows 7 64 bit
    32Gb DDR 3
    WD 1Tb Black
    HP
    Architectural
    AutoCAD 2014
    Jun 2008
    Victoria, Australia
    219
    Quote Originally Posted by MillerMG View Post
    Just curious
    My LISP was a lot more basic than the main one you have and only used if you were inside a viewport already.
    You already wrote that bit out.
    Code:
    I also made some with specific variations for certain layer names to get thawed or frozen to suit a type of plan I was creating.
  9. #9
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    449
    That is much more simple. I may have to change my LISP. Thanks Andrew!!
  1. viewport Layers Frozen/Thawed
    By prodromosm in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2015, 12:35 am
  2. Capture off and frozen layers in a viewport?
    By j_spawn_h in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th May 2013, 06:37 pm
  3. Frozen layers re-appear in viewport set to conceptual when saving
    By Stoofer in forum AutoCAD Drawing Management & Output
    Last Post: 25th Nov 2010, 10:06 am
  4. Copy a Viewport & keep VP Frozen Layers
    By cedwards in forum AutoCAD General
    Last Post: 28th Feb 2010, 10:35 pm
  5. Frozen Layers in Viewport Re-appear When I Reload an Xref
    By Unick in forum AutoCAD Drawing Management & Output
    Last Post: 21st Sep 2006, 04:23 pm
Tags for this Thread
