Rename a Block
Casio47
Hello All...
I found my block in the Design Center, How do I rename it? And, how do I delete blocks that I dont want in the Design Center?
Thanks for the help
RENAME Command is the way to go; programming will be required to rename blocks in closed drawings though, so just open, rename, etc.
If (when?) you tire of using RENAME Command via dialog/command line, as I did, you may find this App to be of use... Just select the block, and right click:
Should you be interested, please see the Exchange Apps link in my signature.
Cheers
You can rename a block in your drawing using the RENAME command or REN for short.
OK, RENAME works. How do I delete a block I no longer want. When I use the purge command, the block remains. I believe the Block I wish to delete is just a name, with out any drawing assigned to it. I managed to do this in the Design Center when I was trying to rename my block. I messed it up...
Cheers
Having used this previously when renaming a block library, this is a good app that I would recommend :)
The $1 cost is trivial compared to the amount of time (and boredom) saved.
Thank you, Organic; that is very kind of you to say. :oops: :beer:
Cheers
