Results 1 to 8 of 8
    Senior Member bababarghi's Avatar
    bababarghi's Computer Details
    HP z440
    Intel Xeon 3.5GHz
    32GB
    NVIDIA Quadro K4200
    Electrical
    AutoCAD 2017
    May 2013
    136
    Default Can't FLATTEN a particular drawing
    Hi all,
    I have a relatively small drawing with couple of blocks which is ridiculously large on disk (currently 1.4MB after couple of PURGE and AUDIT). There should be some elevated geometry in the drawing. The drawing looks pretty flat in side view though. The method I use to understand whether my drawing is purely 2D or not, is DGNEXPORTcommand. Here is what I get for this particular drawing after running dgnexport:
    I tried FLATTEN command but it takes ages and then machine freezes.
    File size is bigger than attachment limit. So I uploaded it here:
    HTML Code:
    http://s000.tinyupload.com/index.php?file_id=83646937124174024565
    Can someone plz tell me what's wrong with this drawing?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    If you look from the side view, there are 2 blocks that are occupying 3D space because they have an insertion point on Z=0 but the geometry is elevated. This is causing the problem
    HP z440
    Intel Xeon 3.5GHz
    32GB
    NVIDIA Quadro K4200
    Electrical
    AutoCAD 2017
    May 2013
    136
    Thanks steven-g. Can you name the block? Or perhaps give me a screenshot?
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    2 blocks "MVI56E-MCM" & "MVI56E-MNET"
  5. #5
    HP z440
    Intel Xeon 3.5GHz
    32GB
    NVIDIA Quadro K4200
    Electrical
    AutoCAD 2017
    May 2013
    136
    Hmmm. I see.
    Is there any systematic way of fixing these kind of issues? I mean what's the common practice? Other than point by point visual inspection of course.
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    Express tools in Autocad has a flatten command, but I have no idea how it is used as it isn't available in LT (we have to use different methods). So I don't know if it will work for geometry within a block, hopefully someone with full Autocad will join in and let you know.
  7. #7
    HP z440
    Intel Xeon 3.5GHz
    32GB
    NVIDIA Quadro K4200
    Electrical
    AutoCAD 2017
    May 2013
    136
    Quote Originally Posted by steven-g View Post
    Thanks for bothering and helping me out. I have a full version and I already explained about FLATTEN command in my first post. Nested blocks are the problem here.
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    The problem within the blocks is just the text item "prosoft communications" it has a Z value, you can open up the blockeditor and see and alter the Z value. No idea why that would cause "flatten" to hang on your system, maybe you would need to open the blocks individually in the blockeditor and use the flatten command.
  1. Please help flatten my drawing
    By kizaerf in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2014, 12:53 pm
  2. Flatten 3D drawing to 2D
    By gtwatson in forum AutoCAD Beginners' Area
    Last Post: 25th May 2011, 01:15 pm
  3. How do i flatten a drawing?
    By mattbarb in forum AutoCAD General
    Last Post: 28th May 2008, 07:22 pm
  4. flatten drawing to 2d
    By jkaran in forum AutoCAD Drawing Management & Output
    Last Post: 12th Dec 2005, 09:10 pm
  5. Flatten a drawing
    By Vince0115 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Apr 2005, 09:36 pm
Tags for this Thread
