Dynamic Block with different x,y,z scale?
Jmclachlan
As a result of multiple updates of AutoCAD software and addition of 12D software I have lost the ability to block replace a block with different x,y,z scales with a dynamic block and have the dynamic block retain its function. Is there a way for the dynamic block to work with different x,y,z scales?
The block should scale with no problems, it will just lose it's dynamic ability when using diffrent scales for X,Y and Z, so you can still use it with it's dynamic functions at equal scale values, then change the scale to suit what you need
