Hobblenobble Posted January 7, 2016 Share Posted January 7, 2016 Be gentle as I am a newbie!!! Your help will always be appreciated. I want to create a dynamic block that has two attributes. The attributes are a pair. So if one moves, the other moves too. They are located either above or below a line. If visibility is set to upper, then both attributes sit above the line. If visibility is set to lower, then both attributes are below the line. The distance of movement from upper to lower is 8mm. Text height is 3mm. Thank you. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 8, 2016 Share Posted January 8, 2016 Dont play much with dynamic blocks but pretty sure their is an example here of turning attributes on / off so you would duplicate your attributes top & bottom but only 1 set has visibility on, Att1=Att3 Att2=Att4 so only enter 1 time. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 8, 2016 Share Posted January 8, 2016 It's doable, but can you post a copy showing what and where, it takes the guess work out answering Quote Link to comment Share on other sites More sharing options...
Andrew1979 Posted January 8, 2016 Share Posted January 8, 2016 Yes I think if i understand what you are saying it is possible. I would use the Flip parameter though rather than Visibility. I have attached a sample block for you to look at. Block.dwg Quote Link to comment Share on other sites More sharing options...
Hobblenobble Posted January 8, 2016 Author Share Posted January 8, 2016 All, thank you for your responses. Andrew1979 is pretty much spot on with his idea of using flip. However.............. The distance of the flip is based around the mirror line. I would like to make the distance when moving from one side of the line to the other variable. Is it possible to do this with flip (tried unsuccessfully) or would it need the move parameter including ???? Thank you. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 8, 2016 Share Posted January 8, 2016 If you post a copy of a drawing showing the position of items on both sides of the line, then there won't be any reason for people to guess at what you want Quote Link to comment Share on other sites More sharing options...
