Argo Posted January 13, 2016 Share Posted January 13, 2016 (edited) Hi All, I've finally started coding up my own VBA macro that batch creates drawings and attaches Xref, Sets Layer States etc. The issue i'm finding though is that if I run the script after turning the computer on and not running autocad everything runs fine and the script executes everything it needs to and sends commands to AutoCAD. If I then decide I want to change a value and the same instance of autocad is open (the one the macro originally created) everything works fine. But if I close AutoCAD and reopen it, or have already had a instance of AutoCAD open (seperate to to one the macro originally created) the script runs but nothing happens. If i close the excel file and reopen. The macro will run Here is my code Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long) Sub XrefAttach2Dwg() Dim XrefRng As Range, XrefPathRng As Range, cell As Range, cxrefname As String, Xrefpaste As Range, cellx As Range, Alive As String, checkcellRange As Range, Checkcellval As String, fileName As String, pctCompl As Single, inRng As Range, n, myworkbook, cellxval As String, CurrentDWG As String, sleeptime As Integer, Tidy As Integer Dim TempLoc As String Dim LayName As Range Dim acadApp As Object TempLoc = "File Path/Drawing.dwt" Set XrefRng = Range("Xref_Attach_Range") Set XrefLookup = Range("Xref_Lookup") Set inRng = Application.Range("Table4[DWG Path]") Set wS1 = Worksheets("Send AutoCAD Commands") Set XrefPathRng = Range("Xref_Paths") Set outCell = wS1.Range("E18") 'change to be first cell of output range Set inlay = Application.Range("Table4[Layout]") 'set copy location of layout name Set outlay = wS1.Range("F16") 'set paste location of layout name i = 0 Startcolumn = "F" Endcolumn = "N" n = 0 Currrow = 18 Application.ScreenUpdating = False Checkcellval = Worksheets("Project builder").Range("F6").Value '------------Checking if XRef's Exist------------------- For Each checkcell In XrefPathRng Checkcellval = checkcell.Value 'MsgBox checkcell.Address If Checkcellval = "" Then GoTo SkipCell Else End If If Dir(Checkcellval) <> "" Then 'MsgBox "File exists." Else MsgBox ("The following Xref does not exist:" & vbNewLine & Checkcellval & vbNewLine & "Please check the file and try again") Exit Sub End If i = 1 + i SkipCell: Next checkcell '-------End Checking Xrefs--------------- If MsgBox("Excel and AutoCAD will not be accessible during the operation Are you sure you would like to continue?", vbYesNo) = vbNo Then Exit Sub Worksheets("Project Builder").Range("F19").Select '-------------Creating Drawing-------------------- For Each incell In inRng 'incell.Select 'MsgBox incell CurrentDWG = incell.Offset(0, -11).Value Set LayName = Worksheets("Project Builder").Cells(incell.Row, 1) If Dir(incell.Value) <> "" Then Tidy = 1 GoTo DWGExist Else [b]On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If Err Then Err.Clear Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If[/b] ' Set acadApp = GetObject(, "AutoCAD.Application") ' acadApp.Visible = True 'If acadApp Is Nothing Then 'Sleep (3000) 'Set acadApp = CreateObject("AutoCAD.Application") 'acadApp.Visible = True 'Alive = "Yes" 'Else 'Alive = "No" 'End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If AutoCAD.Application.Documents.Open TempLoc AutoCAD.Application.ActiveDocument.SendCommand ("LAYOUT" & vbCr & "R" & vbCr & "000" & vbCr & LayName & vbCr) 'renames the layout from default "000" to the name stored in LayName AutoCAD.Application.ActiveDocument.SaveAs incell.Value, AcSaveAsType.ac2007_dwg 'Saves the drawing to the incell value in a 2007 DWG format UserForm1.DWG.Caption = "Created" & CurrentDWG 'Updates the progress indicator to display drawing created End If 'Progress Bar Code Start pctCompl = (n / (Range("Table4[DWG Path]").Count)) * 100 progress pctCompl progressDWG CurrentDWG 'Progress Bar Code Ends 'End If '--------Searching XrefRange For Instances of "Yes"--------------- Sheets("Project Builder").Select Currrow = Currrow + 1 Set Currrange = Range(Startcolumn & Currrow & ":" & Endcolumn & Currrow) For Each cell In Currrange 'cell.Select Sheets("Project Builder").Select If cell.Value = "Yes" Then sleeptime = 2000 cxrefname = Cells(17, cell.Column).Value 'MsgBox cxrefname & " " & ActiveCell.Address 'Use for Testing Variable Value Else sleeptime = 100 cxrefname = "No Xref to Attach" End If '--------once it finds an instance of yes search for Xref particulars------------- Sheets("Project Builder").Select For Each cellx In XrefLookup cellxval = cellx.Value If cellxval = cxrefname Then Set Xrefpaste = cellx.Offset(0, 1) fileName = Replace(Dir(Xrefpaste), ".dwg", "") AutoCAD.Application.ActiveDocument.ActiveSpace = acModelSpace AutoCAD.Application.ActiveDocument.SendCommand ("FILEDIA" & vbCr & "0" & vbCr & "-Xref" & vbCr & "o" & vbCr & Xrefpaste & vbCr & "0,0" & vbCr & "1" & vbCr & "1" & vbCr & "0" & vbCr & "FILEDIA" & vbCr & "1" & vbCr) 'Attaches Xref into Drawing AutoCAD.Application.ActiveDocument.SendCommand ("FILEDIA" & vbCr & "0" & vbCr & "-rename" & vbCr & "b" & vbCr & fileName & vbCr & cxrefname & vbCr & "FILEDIA" & vbCr & "1" & vbCr) 'Renames Xref from default name to that specified in Project builder UserForm1.DWG.Caption = "Attaching Xrefs to " & CurrentDWG 'Updates Progress Indicator to display that Xrefs are currently being attached to Drawings Else End If Next cellx '--------End searching for xref particulars------------ Next cell AutoCAD.Application.ActiveDocument.SendCommand ("FILEDIA" & vbCr & "0" & vbCr & "FILEDIA" & vbCr & "1" & vbCr & "COMMANDLINE" & vbCr) 'Quick Saves Drawing AutoCAD.Application.ActiveDocument.Save AutoCAD.Application.ActiveDocument.Close 'Closes AutoCAD Sleep (sleeptime) n = n + 1 Tidy = 0 DWGExist: Next incell '----------------End Searching XrefRange For Instances of "Yes"---------------- If Tidy = 0 Then Sheets("Send AutoCAD Commands").Range("C13:O73").ClearContents AutoCAD.Application.ActiveDocument.SendCommand ("FILEDIA" & vbCr & "1" & vbCr & "COMMANDLINE" & vbCr) If Alive = "Yes" Then AutoCAD.Application.Quit End If Else End If [b]acadApp.Quit Set acadApp = Nothing[/b] Application.ScreenUpdating = True pctCompl = 100 UserForm1.Bar.Width = 246.5 progress pctCompl MsgBox "The project has been built. " & vbNewLine & n & " Drawing(s) were created.", vbInformation, "Done" End Sub I'm assuming the script runs because the on error resume next allows it to, however it doesn't do anything because the process isn't killed? Edited January 13, 2016 by Argo Quote Link to comment Share on other sites More sharing options...
Argo Posted January 14, 2016 Author Share Posted January 14, 2016 Just to add some comments I actually think I may be dealing with an orphaned acad.exe process. What's the best way to deal with closing off these objects. Quote Link to comment Share on other sites More sharing options...
RICVBA Posted January 20, 2016 Share Posted January 20, 2016 It might have to do with - your use of AutoCAD.Application.ActiveDocument reference, which would always stick to the first AutoCAD session ever opened and available at the time your VBA macro first starts so that should that session get closed that reference in your code would throw an error (some "remote server not existent or not available", or "error automation" or stuff like that) - your simultaneous use (and let aside as well) of "acadApp" variable add to this that "GetObject()" method always returns the first instance of AutoCAD in the Windows Running Object Table available so, to (hopefully) thoroughly understand the implications of what above and (even more hopefully!) learn how to handle it, lets' try this: - close all of your AutoCAD sessions and Excel workbook that holds your macro too - open AutoCAD session #1 and set "Drawing1" as its active document name - open AutoCAD session #2 and set "Drawing2" as its active document name - open Excel and its VBA IDE and type in this simple macro Sub test_AcadSessions() Dim okStop As Boolean Dim acadApp As Object Do While Not okStop Set acadApp = GetObject(, "AutoCAD.Application") 'Get a running instance of the class AutoCAD.Application acadApp.ZoomExtents MsgBox ("AutoCAD.Application.ActiveDocument.Name: " & vbCrLf & AutoCAD.Application.ActiveDocument.Name) MsgBox ("acadapp.ActiveDocument.Name: " & vbCrLf & acadApp.ActiveDocument.Name) okStop = MsgBox("Stop?", vbYesNo) = vbYes acadApp.ZoomExtents Set acadApp = Nothing Loop End Sub - run that Macro: 1) you'll get "AutoCAD.Application.ActiveDocument.Name: Drawing1.dwg" 2) press OK you'll get "acadapp.ActiveDocument.Name: Drawing1.dwg" 3) press OK 4) at the message box asking "Stop?" - don't press any button on the message box - open a new AutoCAD session #3 and have its active document named after "Drawing3" - switch to AutoCAD session #1 and close it - finally go back to message box and press "NO" you'll get an error message thrown from acadApp.ZoomExtents since "acadApp" variable is still referencing to what it was last set by Set acadApp = GetObject(, "AutoCAD.Application") statement and thus pointing at the first AutoCAD session available at that moment, i.e. that session #1 you just closed right under its nose! 5) skip that statement (just drag the yellow arrow to the following one) and press F5 to make the macro go on the macro will silently (no error) process the Set acadApp = GetObject(, "AutoCAD.Application") statement that will have "acadApp" variable pointing at session #2, it being the first available AutoCAD session "now" (as opposed to "ever") you'll get an error message again! this time it's thrown from MsgBox ("AutoCAD.Application.ActiveDocument.Name: " & AutoCAD.Application.ActiveDocument.Name) since "AutoCAD.Application" reference is still pointing at that first AutoCAD session available "ever" (as opposed to "now"), i.e. the first available at the moment your macro started (session #1 you closed at step 4) and it would always do that until you stop/finish the macro and close its workbook! 6) skip that statement, press F5 and make the macro go on you'll get "acadapp.ActiveDocument.Name: Drawing2.dwg" thus no error. and that's because acadApp variable has been reset to point at session #2 (as explained at the beginning of step 5) 7) press "OK" eight) at the message box asking "Stop?" - don't press any button on the message box - switch to AutoCAD session #2 and close it - finally go back to message box and press "NO" well, by now you should know what to expect you'll get an error message thrown from acadApp.ZoomExtents since "acadApp" variable is still referencing to AutoCAD session #2 it was last set to and you just closed right under its nose, once again! (same mechanism of step 4) 9) skip the statement throwing the error (you already know it, it's the "acadApp.ZoomExtents" one) and press F5 to make the macro go on the macro will silently process the Set acadApp = GetObject(, "AutoCAD.Application") statement that will now have "acadApp" variable pointing at session #3, it being the first (and the only) available AutoCAD session "now" and, yes, you'll get an error message thrown from that nasty MsgBox ("AutoCAD.Application.ActiveDocument.Name: " & AutoCAD.Application.ActiveDocument.Name) since "AutoCAD.Application" reference is still pointing at the first AutoCAD session available "ever" (i.e. the long dead but still in our hearts session #1) 10) skip that statement, press F5 and make the macro go on of course you'll get "acadapp.ActiveDocument.Name: Drawing3.dwg" well,bottom line? always set and use an "acadApp" by Set acadApp = GetObject(, "AutoCAD.Application") reference instead of using an "AutoCAD.Application." one when you 're finished with an autocad session, quit it and set its reference (acadApp) either to nothing or to another AutoCAD session once you quit an AutoCAD session you'll never be able to reference it (of course!) again and if your acaApp variable was pointing at that session then you must reset it with either a GetObject() method (which will get the first available session at that moment - "now") or a CreateObject() method (which will start a brand new AutoCAD session) hope this will help Quote Link to comment Share on other sites More sharing options...
Argo Posted January 22, 2016 Author Share Posted January 22, 2016 Nailed it, it certainly was the use of acadApp and Autocad.Activedocument causing the error. Thanks for the detailed response Quote Link to comment Share on other sites More sharing options...
