Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    Unhappy RGB to ACI colour, can I automatically convert RGB objects to autocad colours?
    Hello there,
    I have a file (probably exported from rhino, not sure about that though) where all objects have rgb colour properties to them. White lines are RGB 255, 255, 255, which makes them look fine in model space, though they look white on white in paper space. I would like to convert those objects to WHITE, so that I can set a print profile that would make them print black if that makes sense? At the moment I can only select the objects one by one, which is nearly impossible as the drawing is quite big. I tried to use quickselct, which kind of worked, though it did not allow me to select objects belonging to blocks (of which there are plenty, unfortunately!).
    Thanks a lot for any help!
    G
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Ignoring the other part for the moment this is a possible way of getting at the colour values, you could do a selection and pick what you want as a using "X" could produce some odd results. As in the example you would need some form of list like 255,255,255 is color index now 7 White/black and Colormethod = 195
    Code:
    maybe this will work
    ; get the colour values
    (setq obj (vlax-ename->vla-object (car (entsel)))) ; pick an object
    (setq col (vla-get-TrueColor obj))
    (vlax-Dump-Object col)
    this is a RGB
     IAcadAcCmColor: AutoCAD AcCmColor Interface
    ; Property values:
    ;   Blue (RO) = 38
    ;   BookName (RO) = ""
    ;   ColorIndex = 52
    ;   ColorMethod = 194
    ;   ColorName (RO) = ""
    ;   EntityColor = -1025917402
    ;   Green (RO) = 190
    ;   Red (RO) = 217
    this is colour 152
    ; IAcadAcCmColor: AutoCAD AcCmColor Interface
    ; Property values:
    ;   Blue (RO) = 204
    ;   ColorIndex = 152
    ;   ColorMethod = 195
    ;   EntityColor = -1023410024
    ;   Green (RO) = 102
    ;   Red (RO) = 0
    (vla-put-ColorMethod col 195)
    (vla-put-ColorIndex col x) ;x is 1-255
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    Hello Bigal, thanks for your reply!
    unfortunately I could not understand much of it! :-)
    I might not be an advanced enough cad user (I have not used any code before). I did however try to paste the code you posted into the command line, but that led to no results. Sorry I think it's me making some mistake here!
    Could you please be more precise as to how to use the code? Should I paste everything into the command line? should I omit some lines? Should I aste the code in different batches? etc...
    Many thanks!
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    I need to do some more homework as well.
  5. #5
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,238
    Can't you just open your layer manager and change the layers that are 255,255,255 to white? Or is there a color override on the objects so that color is not set bylayer?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  6. #6
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    Hi Cad64,
    thank you for your comment!
    and yes, unfortunately I cannot change objects colour through changing layers properties as objects are indeed individually overwritten. I could select them one by one but it would take ages (and I would also have to explode or enter all blocks!).
    I have done more researching into the origin of the file, which I now know, was definitely made with rhino. There, all objects were just rgb white, regardless of their layer.
    Any idea, now...?
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    QSelect by color should select all 255,255,255 objects, then change to white or ByLayer.
    For blocks see if this thread for setting All Objects in Blocks to Layer 0 helps.
  8. #8
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    Hi SLW210!
    yeah qselect works, had successfully tried that. Unfortunately I could not work with the thread you recommended as I have never worked with codes and I do not seem to be able to make sense of that :-(
    Sadly, I do not know what a lisp is.
    If you could guide me through how to make us of that thread I will be grateful. Am I supposed to copy the des in the boxes in the command line at all? Should the all thing be pasted in there at once? I have tried that but autocad does not seem to respond by moving all objects in blocks to layer 0, which is what those commands are supposed to do, right?
    thanks a lot!
  9. #9
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    How to use LISP.
    If it is LISP in a Code Tags (like the ones on the link I posted), just copy all of the contents in the code box to Notepad and save as a .lsp , if you see a defun c:norm2 in the code, then the norm2 is the command to call the LISP.
  10. #10
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    ok I will try that, thanks a lot.
    just a quick question: the first code does not read defun c:norm2. Instead, it says: defun c:fixblocks
    how do I call the LISP in this case?
    many thanks
  1. How to convert layer colour properties on multiple drawings quickly?
    By misskiti in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2013, 10:44 am
  2. Convert from index colours to true colours
    By djguinan in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2012, 05:50 pm
  3. HELP Looping 'Convert Bylaer colour and linetype'
    By Micko79 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Nov 2011, 05:01 pm
  4. Convert all layer colours to white - and back again
    By geo in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Nov 2008, 01:59 am
  5. How do you automatically set layers you want objects on?
    By echochamber in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Oct 2006, 06:10 am
Tags for this Thread
