Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
  1. #11
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    Quote Originally Posted by GMaracchioni View Post
    just a quick question: the first code does not read defun c:norm2. Instead, it says: defun c:fixblocks
    how do I call the LISP in this case?
    There are several lisp routines in that thread. The ones from chulse and fuccaro are the "fixblocks" routines, but if you scroll down further, there is one from kpblc which is the "norm" routine. And on page 3 there is the "norm2" routine. So it depends on which one you decide to use.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  2. #12
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    and whichever I use is the same procedure, except I need to call them up by typing in the routine name in the command line? so norm2, or fixblocks, orn norm, etc in the command line? can I name the 'lsp file anything I want, and can I save it anywhere?
    sorry for bombarding you guys with questions, and thanks for your help!
  3. #13
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    I just noticed you're using Autocad LT. Sorry but you can't run lisp routines in Autocad LT.
    Since you are using LT, you should post your questions in the Autocad LT section: http://www.cadtutor.net/forum/forumd...?82-AutoCAD-LT
    Facebook:
  4. #14
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    right...well thank you for your help anyway
  5. #15
    Forum Newbie
    AutoCAD LT 2013
    Jan 2016
    8
    Default RGB to ACI colour, can I automatically convert RGB objects to autocad colours?
    Hello there,
    I have a file (probably exported from rhino, not sure about that though) where all objects have rgb colour properties to them. White lines are RGB 255, 255, 255, which makes them look fine in model space, though they look white on white in paper space. I would like to convert those objects to WHITE, so that I can set a print profile that would make them print black if that makes sense? At the moment I can only select the objects one by one, which is nearly impossible as the drawing is quite big. I tried to use quickselct, which kind of worked, though it did not allow me to select objects belonging to blocks (of which there are plenty, unfortunately!).
    Thanks a lot for any help!
    G
  6. #16
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    I combined your threads, sorry I totally missed you were using LT.
    Unfortunately, using LT you are stuck with doing the blocks manually, or exploding the blocks.
    You might try getting a forum member with full AutoCAD to fix the blocks.
  1. Convert from index colours to true colours
    By djguinan in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Feb 2018, 08:15 pm
  2. How to convert layer colour properties on multiple drawings quickly?
    By misskiti in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2013, 10:44 am
  3. HELP Looping 'Convert Bylaer colour and linetype'
    By Micko79 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Nov 2011, 05:01 pm
  4. Convert all layer colours to white - and back again
    By geo in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Nov 2008, 01:59 am
  5. How do you automatically set layers you want objects on?
    By echochamber in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Oct 2006, 06:10 am
Tags for this Thread
