Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Junior Member
    AutoCAD 2018
    May 2014
    21
    Default Drawing Thiessen polygons(rainfall)
    Hello there!
    I have a project due Tuesday and I have to calculate the precipitation using thiessens polygons.I have georeferenced the map , drawn the basin, connected the 6 points together and formed 4 triangles.
    Now im having troubles drawing "Perpendicular Bisectors of the Sides of a Triangle".In few occassions the circle is too big and lines do not meet in the center of the circle.I have tried (Osnap On midpoint)+perpendicular but the lines do not meet at all. If somebody can help me that would be great.
    Sorry for the terms that im using but im trying to explain it as good as possible.
    Thank you.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Hopefully follow this
    Line Pick point inside triangle PERP pick triangle side, move line to mid of triangle side,
    repeat for a second side.
    where the lines cross is centre of circle.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    According to the laws of plane geometry, if the triangle intersects the circle at all three apexes, then a line drawn from the center of the circle to any of the three sides, at the perpendicular point on the side will bisect the triangle side. Simply, any line drawn from one point on a circle to another point on the same circle will have a midpoint that will be perpendicular to the center of the circle.
    Start by turning on the center, midpoint, and perp snaps, then insure that the triangle sides actually meet at all three apexes. Then continue by drawing the circle using the 3P (three point) option, using the apex points of the triangle. Then draw three lines from the circle to the perp snap of each triangle side.
    You can draw two of the lines from the midpoint of the triangle sides directly to the center of the circle, assuming everything is accurately placed. The third side needs a temporary line to provide an accurate midpoint since the third side (SE) is made up of two lines.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    If you have polar tracking on, then just pick the midpoint of a side of the triangle, and directly draw the perpendicular bisector. Then the centre of the circle will be at the intersection of these lines
  5. #5
    Junior Member
    AutoCAD 2018
    May 2014
    21
    Thanks a lot for the replies. I tried drawing circles using 3 points and then drawing perpendicular lines at the midpoints of each triangle.
    The red circles are perfect but the blue circles are pretty big and their center is not inside the triangle.
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    It would help AutoCAD if you were to use layers. If you draw the triangles on their own layer and then freeze all other layers, you would find no difficulty in drawing the geometry.
    I think that some of your midpoint snaps might have been confused because there were more than one line where the pick was.
    There is no compulsion for the centre of the circle to be inside the triangle.
  7. #7
    Junior Member
    AutoCAD 2018
    May 2014
    21
    Quote Originally Posted by eldon View Post
    Sorry but I don't know how to use layers.
    I moved other lines out of the way and then I picked the midpoint and then I put everything back together.
    Is there any way to convert an autocad file into .TIF becouse I think I might be able to do it in QGIS.
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Use layers and assign each a different color. It is counterproductive to draw everything on one layer (layer "0") then override the default color (white).
    Create your layers in the Layer Properties Manager. Layers can be turned on/off or frozen/thawed. They can even be locked/unlocked as well as isolated/unisolated.
  9. #9
    Junior Member
    AutoCAD 2018
    May 2014
    21
    But if the center of the circle is not inside the triangle there is no way I can draw Thiessen Polygons.
    I used layers for every single drawing that I made.
    For the triangles in the bottom I used region command then massprop and found the centroid but the results midpoint and the perpendicular line are not in the same place.
    Points-White
    Triangles-Blue
    Correct perpendicular bisectors- green
    Correct circles-mangenta
    ------------------Here is the part that im having difficulties---------------------------------
    Centroid of the triangle using region and massprop-red
    Perpendicular-yellow
    Midpoints-red
    Incorrect circles(IMO)-orange
  10. #10
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    Your trouble lies with the positioning of the base points. To draw triangles with a circle centre within the triangle means that no angle in any triangle can be greater than 90 degrees.
    You need more points!
  1. polygons
    By dbroada in forum .NET, ObjectARX & VBA
    Last Post: 20th Feb 2013, 08:05 pm
  2. Loop whole entities of CAD drawing and extract arc or polygons
    By isxhy in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jan 2013, 06:54 pm
  3. hatch with polygons
    By jalba in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2010, 12:15 pm
  4. polygons in iso
    By driftingsun3 in forum AutoCAD Beginners' Area
    Last Post: 4th Apr 2008, 10:55 am
  5. Need help with polygons
    By shannon188 in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2005, 02:43 pm
