Results 1 to 3 of 3
    Forum Newbie
    Civil 3D 2014
    Nov 2015
    6
    Default Problems with UCS and attaching xrefs
    Hello Folks!
    Having problems with the UCS at the moment.
    I have rotated my drawings with the UCS command and used the plan command to set the drawings in the angle i want to view them in.
    And then used world to get the co-ordinate system true to its original state.
    The problem is when i am trying to attach the drawings together, they are in different places.
    Do you guys have any clues?
    (Sorry for my bad english)
    /Per-Anton
    Full Member
    dkeran's Computer Details
    Dell
    32
    Civil
    dkeran's Discipline Details
    CAD Manager (Contractor)
    Civil
    AutoCAD 2016
    Oct 2015
    Dublin, Ireland
    49
    Possible check the xrefs you are attaching to see if they are in the same co-ordinate system and scale that your main drawing is in?
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    658
    Or.
    Check INSBASE for insertion point of dwg xref (check both, should be 0,0,0)..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  1. attaching xrefs to dwgs
    By humpo in forum AutoCAD General
    Last Post: 29th Nov 2012, 02:48 pm
  2. Attaching XREFS to many drawings (methods)
    By mrharris78 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2012, 09:03 pm
  3. Problems with xrefs
    By RobRodek in forum AutoCAD General
    Last Post: 30th Oct 2011, 07:07 pm
  4. Attaching Objects, Attaching Vertex, Cutting holes
    By evanesp26 in forum 3D Modelling
    Last Post: 8th Feb 2010, 07:50 am
  5. problems controlling appearance of nested xrefs
    By smollensky in forum AutoCAD Drawing Management & Output
    Last Post: 26th Apr 2006, 07:48 pm
Tags for this Thread
