Kowal Posted January 15, 2016 Share Posted January 15, 2016 Is there a system variable that controls properties - lineweight points. On my printouts points to a default width. I use AutoCAD 2014. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 15, 2016 Share Posted January 15, 2016 If I understand your question, your pen settings control that. Quote Link to comment Share on other sites More sharing options...
Kowal Posted January 15, 2016 Author Share Posted January 15, 2016 Why point (AutoCAD point) does not change its width? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 15, 2016 Share Posted January 15, 2016 If you are using a .ctb, change the color to red. If you are using a .stb, change the lineweight of the layer. An alternative would be to plot using object lineweights. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 15, 2016 Share Posted January 15, 2016 You cannot change the lineweight of an AutoCAD Point. Lineweights also do not affect TrueType fonts or raster images. You could make a block that looks like a Point. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 15, 2016 Share Posted January 15, 2016 You cannot change the lineweight of an AutoCAD Point. Lineweights also do not affect TrueType fonts or raster images.You could make a block that looks like a Point. I must be special because the lineweights of my points respond to changing the color and using a .ctb. Quote Link to comment Share on other sites More sharing options...
