4RIDERS Posted January 18, 2016 Share Posted January 18, 2016 (edited) Hello, i try to do sweep command. i have used with no problems until now. When i used sweep command it was sweeping this shape into a solid. Now, when i sweep it converts it into a surface. Do you have a solution to sweep this shape into a solid and not in a surface ? dormitor lupu.dwg i tryed sweep command with surface mode 1 - 0 but it creates surface or nurbs surfaces. i tryed extrude command with solid mode on but it says : path curve is coplanar with or tangent to the plane of the profile curve Edited January 18, 2016 by 4RIDERS Quote Link to comment Share on other sites More sharing options...
