WTFD4V1D Posted January 18, 2016 Share Posted January 18, 2016 Hi, I'm having an issue where anything I copy (either from this drawing or another drawing) and paste into this drawing comes in as one block. For example, if I copy a couple of text lines and detail bubbles and paste it, it comes in as an entire block and I can't move each item around or edit them at all. I'm not sure why that is. I had some xrefs on there but they were about 60mb so I've just uploaded the single file with all the xrefs removed for the time being. Don't know if an xref can cause a problem or not so I didn't include it. 1603-S1.5-FLRtest.dwg Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 18, 2016 Share Posted January 18, 2016 It looks like it is a local issue. Pasting multiple objects works as expected here. Does this happen in all your files? Explain exactly how you are pasting. Quote Link to comment Share on other sites More sharing options...
WTFD4V1D Posted January 18, 2016 Author Share Posted January 18, 2016 It looks like it is a local issue. Pasting multiple objects works as expected here. Does this happen in all your files? Explain exactly how you are pasting. No, just this one. I used to have two xrefs on here. When I remove just one of them and keep the other, everything pastes fine for me. It's just when I have two xrefs for some reason. I'm using Ctrl+C and Ctrl+V to copy and paste. Works on the other drawings, just not this one. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 18, 2016 Share Posted January 18, 2016 If it is only the one file, explode the block(s) after pasting. Quote Link to comment Share on other sites More sharing options...
