Results 1 to 8 of 8
    Forum Newbie
    Map 3D 2013
    Jan 2016
    3
    Default Changing color of blocks according to elevation attribute
    Hi everyone,
    I imported some bathymetric coordinates to AUTOCAD map 3d, they appeared as individual blocks, the numbers with a centered cross. I kept only the elevation attribute, adjusting size and position. After that, I had some issues, following:
    I have to put them into a map, in different sizes and rotation angles according to the place, I made different blocks, separating above 10 meters and below 10 meters, because of the position of the numbers (have to be centered, matching the comma with the cross, and they vary depending on the numbers - 1 and 2 digits), and the blocks got mixed in their properties (size and color). I left them like that for a while, because I did manually, but I'm trying to solve this with some routine or queries.
    I also need to classify the different depths with colors, according to the location. Is there a way to do it? Is it better to change from blocks to text? I'm trying to do a query for that, but is not working for blocks or text, I guess I am doing something wrong. Could you please, help me? Thanks in advance.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    It would be simple to change the color of text just read the text value and apply the correct color. You may be able to use a field. can you psot a dwg
    Forum Newbie
    Map 3D 2013
    Jan 2016
    3
    Hi, there are thousands of numbers. That's why I'm trying to work with blocks and queries, if it's possible. Follows a sample attachedAttachment 56794Attachment 56794
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    It would probably be easier to test any proposed solutions if you were to attach an actual copy of the .DWG file. Images, in most cases, are just pretty pictures and that's about it.
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    CIV3D does nice rainbows as a contour option.
  6. #6
    Forum Newbie
    Map 3D 2013
    Jan 2016
    3
    Hi, I send an example. The numbers in black are the minimum zone depth and all the blue values which are below this should have red color, according to the stated for the zone.
    Is there a way to do this at once? A lisp/query/etc.?
    Thanks in advance
  7. #7
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,316
    I have moved your question to the Map 3D section: http://www.cadtutor.net/forum/forumd....php?59-Map-3D
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Try this
    Code:
    ; change color of a block
    ; by Alan H Feb 2016
    (vl-load-com)
    (defun c:rlred ( / rl len x val)
    (setq rl (atof (vla-get-textstring
             (vlax-ename->vla-object
             (car (entsel "Pick rl"))))))
    (setq ss1 (ssget (list (cons 0 "INSERT")(cons 2 "Map_Survey_Point"))))
    (setq len (sslength ss1))
    (setq x len)
    (repeat len
    (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq x (- x 1)) )) 'getattributes)
    (setq val (atof (vla-get-textstring att)))
    (if (< val rl)
    (vla-put-color att 10)
    (command "regen")
    (C:rlred)
  1. changing all nested blocks' color to bylayer
    By NoelStalker in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Apr 2016, 06:20 pm
  2. Changing attribute layer and color
    By WPerciful in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Dec 2015, 01:05 pm
  3. Changing color of lines within multiple blocks
    By Elizanoloo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Aug 2014, 06:47 am
  4. Changing color of circles in Blocks only
    By Michaels in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Feb 2011, 02:17 pm
  5. changing color in color control (layer )
    By ionica in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2005, 07:45 pm
Tags for this Thread
